Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By MrJack
Thread: Microwave brewing
    Banned
    Nov 2013
    Victoria
    62
    Microwave brewing
    Can coffee be brewed in a microwave oven? What might be the result if attempted?
    17,094
    Give it a try and let us know what you think...
    Senior Member mwcalder05's Avatar
    Jan 2012
    Sunshine Coast
    437
    How would you actually do this?
    17,094
    Quote Originally Posted by mwcalder05 View Post
    I have absolutely no idea mate...
    Mar 2013
    1,281
    It could work; grinds in mug of water, nuke it, filter. Whether it'd be any good...
    Sep 2013
    52
    It would work fine if you had a filter. Just nuke water to 90-odd degrees, put in the grinds, brew for your desired time, and filter. Pretty much the same way as you would do with a French press.
    I wonder what it would be like if you put the grinds inbefore nuking....
    Oct 2011
    1,376
    Boiling water (sans grinds) in a microwave can be very dangerous and should not be recommended. It is possible to superheat the water (which means to heat it to above it's boiling point without it boiling). When you then put something into it (especially something with a lot of surface area, like ground coffee) it can spontaneously boil (effectively explode) all over you.
    So put the grinds in first!
    Journeyman likes this.
    Apr 2010
    558
    That's very interesting. How does it happen, surely the pressure in the microwave is the same outside?
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,029
    Mythbusters explain it. Superheating of water (Mythbusters) - YouTube yep its a fact, I've seen it happen, violent reaction.
    May 2008
    4,125
    Boiling water (sans grinds) in a microwave can be very dangerous and should not be recommended. It is possible to superheat the water (which means to heat it to above it's boiling point without it boiling). When you then put something into it (especially something with a lot of surface area, like ground coffee) it can spontaneously boil (effectively explode) all over you. l
    Heating the water in the microwave is fine, just don't overheat it. You might consider nuking it for 45 seconds to a minute depending on cup size and the water temp at the start.
    I would only use the microwave oven to heat the water. Don't put metal or plastic coffee maker components in the oven. If I do a cold drip brew I will store it in the fridge and nuke a cupful for 1 minute.
    May 2009
    Bendigo
    1,029
    Dead right. I had a mate got 3rd degree burns up his arm when he tried to put a spoonful of instant into a nuked cup of water. I'd been standing right next to him when the MW finished and had just moved back to the table and was looking at him when it happened - the contents in the cup literally geysered up over his arm.
    May 2010
    Sydney North Shore
    1,326
    Serve him right for drinking instant.
    Barry
    Mar 2013
    1,281
    Lawl...
    tenchars
    Banned
    Nov 2013
    Victoria
    62
    Thanks for the warnings about super-heating. Best left alone I'm guessing.
