Results 1 to 5 of 5
Thread: XMT7100 problem
    Jul 2014
    3
    XMT7100 problem
    Hi all, I've just PID'ed my machine (Older style Lelit PL042) using an XMT7100 controller. When I switch it on it works perfectly but after a variable amount of time the controller will shut down for no reason I can see. It's mounted externally away from the boiler so I wouldn't think temperature would be an issue (especially given ambient temps in Tassie right now). Am I missing something? or did I just get a dodgy unit? Any suggestions would be very much appreciated!
    Rob
    Mar 2012
    1,275
    What SSR are you using, and where is it located ?
    Jul 2014
    3
    It's a cheapo Fotek 40amp mounted inside the right hand side of the case where the controller is mounted, as far from the boiler as possible.
    Jun 2011
    684
    Suspect dodgy transformer in the controller. It's usually that simple.
    Jul 2014
    3
    Yeah, probably right. I guess $25 doesn't buy a lot of QC. Cheers, Rob.
