Results 1 to 35 of 35
Like Tree6Likes
  • 1 Post By Vinitasse
  • 3 Post By Andy
  • 2 Post By taco
Thread: An American percolator in Australia - power adapter?
    Sep 2014
    12
    Hey all just received a presto percolator. Reading up online, it has some very big fans.
    Problem is it came with the USA power lead.
    So can I stick an adapter on it and use it or do I need a transformer?
    Mar 2004
    Internet
    17,004
    Blog Entries
    1
    You need a step-down transformer.... else you will "let the smoke out" when you plug it in.
    The transformer should match or exceed the current draw of the device, you might find it's a fairly large transformer needed to get this working too.
    (circa $150-$250 for a quality transformer)
    Nov 2012
    206
    Check the power markings on the device (if it has any). Some devices have a full-range power input (eg marked as 100-240VAC) so you can get away with just an adapter.
    Otherwise Andy is right: a transformer is required, and possibly a pretty big one depending on power draw.
    Dec 2011
    Toowoomba, QLD
    133
    "Universal" power input (100-250V, 50-60Hz) usually only applies to some electronic and not electrical items. Anything with a heating element or a mains voltage electric motor is (almost?*) always going to need a transformer. Amazon describes presto percolators as being designed for North American power, so you'll need a transformer.
    *I included "almost" because if I didn't, there is bound to be at least one person on this site who would quickly contradict me.
    Sep 2011
    Canberra
    145
    From the Amazon description of the 12 cup model, it is 120 volts, 60 Hz only.
    You'll need a step down transformer with enough power to handle the startup load
    Nov 2012
    206
    What's the difference between an electronic and an electrical item? ;-)
    Senior Member Vinitasse's Avatar
    Aug 2010
    Mornington Peninsula VIC
    1,251
    Quote Originally Posted by fruity View Post
    Heaps!
    Electrical devices were those which used electrical power but did not include electronic components (transistors, integrated circuits etc.). Examples would be lamps, heaters, vacuum cleaners and kitchen items such as kettles, refrigerators etc.... on the other hand...electronic items, obviously, do incorporate electronic components.
    Yelta likes this.
    Nov 2012
    206
    Quote Originally Posted by Vinitasse View Post
    Heaps!
    Interesting! Can't say I would have ever tried to differentiate the two that way.
    Aug 2010
    1,251
    Whether or not you choose to differentiate these two disciplines or not, they are... in fact... quite distinct and that is why there are Electrical Engineers AND Electronics Engineers and also the reason why, on the one hand, we have Electricians and, on the other, Electronics Technicians.
    The basis of the distinction actually hinges on the exchange of electrons across space. The original "electronic" device was the vacuum tube where electrons flowed from one plate to another across a vacuum. This is the fundamental defining factor. As technology developed printed circuits and chips the concept of electrons moving over space, as opposed to through a conductor only, still fits... whereas... the flow of electrons through a conductor falls within the "electric" realm.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,029
    Vinitasse is pretty well on the money, although some electrical devices do incorporate electronic controlling components.
    Aug 2010
    1,251
    Very true Yelta... but I would argue that any electrical device with added electronic circuitry would fall into the definition of being an electronic device
    Sep 2014
    12
    Thanks all. On the unit itself it says approx (actually a squiggly -) 125v at 10a and approx 250v at 5a.
    Since I'm not going to pay a couple of hundred dollars to run this thing can I just plug it in and see. I don't care if the unit blows as it unusable anyway but if their is a risk of me burning the house down i would rather not.
    My wife has purchased hair straightness from USA and run them without a transformer. So maybe just plug it in and see?
    Jun 2009
    Moonta SA.
    7,029
    Quote Originally Posted by zaheerkha View Post
    Crikey! your a braver man than I am.
    Senior Member artman's Avatar
    Jun 2006
    2,433
    Wow, hopefully the device has a fuse inside that will pop before you do.
    The hair device might be dual voltage? Giving something mains powered double the volts normally generates unwanted excitement.
    Sep 2014
    12
    Not brave probably stupid.
    If I get bored this weekend and I do it I'll post some pics.
    Mar 2004
    Internet
    17,004
    Blog Entries
    1
    Yes stupid.
    This is the Darwin Theory at its best. Asking the question then ignoring the answer is very troll like behaviour.
    The only thing I can think of that would make it more likely to be fatal is to try it in the bath.
    I don't think you are going to be a long term member.
    Dimal, chokkidog and Vinitasse like this.
    Mar 2012
    1,275
    240v direct will blow it ( or the internal fuse ) straight away.
    but for $10 you could try one of the 1600W 240/110 travel converters,.. providing there is nothing much more than heater elements inside.
    I have used them on hair dryers etc OK
    Sep 2011
    Canberra
    145
    I've never seen a $10 travel converter that wasn't just a plug adapter.
    Mar 2012
    1,275
    There are many, just google or try Ebay
    Jun 2008
    78
    Why don't you post a picture of the data plate label?
    Aug 2013
    Rockingham W.A.
    1,422
    Hi zaheerkha
    Don't people bother to read a post before replying?
    In other words it is a dual voltage model... "125v at 10a and approx 250v at 5a" is definitive.
    The only thing you need to know is whether it switches automatically (like most "universal" hair dryers and shavers do these days") or whether there is an actual switch. Often the switch is accessible externally, sometimes you have to pull the machine apart just to flick it.
    Considering I have an early (1970's???) Panasonic percolator and reckon it is the worst way of making coffee in existence, I will be interested in your comments about what ends up in the cup!
    Have fun with your new toy.
    TampIt
    17,094
    This type of device usually uses a Series/Parallel selector switch.
    Parallel for 120V and Series for 240V. If the unit came with a User Manual, it should be explained in there how to make the change from one to the other. If you're not sure, a quick trip to an licensed appliance repairer will sort it out for you in five minutes...
    Sep 2014
    12
    Thanks for the info. I havn't noticed a switch and the instructions don't have any details. I've emailed Presto. Now the waiting game, hopefully they respond.
  24. #24
    Sep 2011
    Canberra
    145
    Quote Originally Posted by blend52 View Post
    Wow, I stand corrected. There is a good reason why those are not sold in stores here.
    From a user review on Amazon
    "I bought this for my trip to Australia to use with my flat iron for my hair. I double and triple checked the max load that this would convert and my flat iron was well within all the limits specified.
    The first time I plugged it in it immediately blew the fuses in our hotel room and fried my favorite flat iron. Thanks a lot."
  25. #25
    Senior Member Mariner's Avatar
    Jan 2012
    217
    I will go in to Walmart and have a look in the next few days to give you an answer if you want.
    Having a lot of stuff from the US and overseas (perks of being a sailor) and a few large and very bulky step down converters, it would surprise me a great deal if any cheaply produced appliance drawing high current (domestic) like this would be capable of voltage switching. I have got away with it in lamps from pottery barn and restoration hardware etc but they are only using low wattage in comparison.
    Please, do not plug in any appliance to 240 that is not specifically designed to use it. Seriously. You could die in the flick of a switch - literally. Is it worth a $40 kettle?
  26. #26
    Sep 2014
    12
    Thought I would give an update.
    Finally grew the balls to try it out. Worked fine. No issues.
    For anyone else who might come across this, the brand is the presto percolator.
    Coffee itself is very different to espresso. Its much milder/smoother. Not to my taste but I'm getting used to it. Always comes out streaming hot which I do like.
  27. #27
    Jan 2012
    217
    Hi Z,
    Nice one. I will certainly look into one next time I'm in the US. I guess they must work for both voltages then Don't think I would have tried it, but glad you did and had no issues.
    Make a good cup?
  28. #28
    17,094
    Just to be clear, which version of the above variations in advice did you try mate....
    Sep 2014
    12
    I plugged it in and used it. Just used an adapter plug from burnings.
  30. #30
    17,094
    Sorry mate...
    Really confused now. So, this was a 120V AC unit plugged into a 120V AC socket or what exactly...
    Sep 2014
    12
    Quote Originally Posted by Mariner View Post
    Hi Z,
    Make a good cup?
    Well its different. The taste is much milder in flavor. Wasn't expecting it to be as strong as an espresso but it was more like tea (not a bad thing just different). I get why some people would like it. I didn't like it at first but its starting to grow on me.
    To be fair I've been using some aldi ground coffee cause I don't currently have a grinder. I could probably add more coffee, currently using 2 tablespoons per cup.
    Ask me in a couple of weeks.
  32. #32
    Jul 2014
    22
    Myer has a similar one - Breville CMP12 Cafe Percilator $119 Breville | CMP12 Cafe Percolator | Myer Online
  33. #33
    Aug 2010
    1,251
    Sorry mate...
    I read it this way... seems to me a 120V AC unit was plugged into an Aussie 240V AC socket using a cheap adapter from Bunnings. Talk about turbo-charged coffee... probably didn't take long to brew up a cuppa. If the RCD didn't trip it might be time to have a sparky look at the panel before everything melts down and bursts into flames
  34. #34
    Dec 2011
    Toowoomba, QLD
    133
    Oh for pity's sake! Once some of you people get an idea in your head you can't get it out again with a crowbar, and it seems fear is what cements it there!
    From post #12 by the OP: "On the unit itself it says approx (actually a squiggly -) 125v at 10a and approx 250v at 5a."
    Translated: "On the unit itself it says ~125v at 10a and ~250v at 5a." A "squiggly -" = ~ = AC.
    As shocking as it is to some of you, it appears to be a dual voltage appliance and the OP has demonstrated it to be such. No fuses blew, no RCDs tripped, and it works! Nothing to see here; move along!
    Enjoy the journey, zaheerkha.
  35. #35
    17,094
    Who pulled your chain mate...
