Results 1 to 16 of 16
Like Tree13Likes
  • 4 Post By coffee_machinist
  • 9 Post By coffee_machinist
Thread: Frankensilvia project report and pics
    Jun 2011
    684
    I've had a few requests now for some photos of my monster Silvia, so here they are for anyone interested!
    The story goes that I somehow ended up with a customer's Silvia, and seeing a pile of new boilers on the shelf I thought I'd see what could be done to shoehorn a steam boiler in there. There really isn't enough metal in a Silvia for any self respecting coffee tech to be satisfied with. I must have been bored that week...
    The design goal was to give the machine all the functions and temperature control of a dual boiler machine in the much smaller Silvia package.
    The list of jobs was as follows:
    Add separate steam boiler - this would be two Silvia boilers joined at the base and modified as needed
    Add auto fill board
    Add hot water spout and solenoid
    Add PID to brew boiler
    Upgrade steam valve
    Add pressure gauges for steam and brew
    Add tank weight sensor switch
    This is the tiny steam boiler heat exchanger. It pre heats the brew water along with some cold water mixed back in.
    The bare chassis with boilers installed. All modifications necessary for putting valves and fittings into the steam boiler are done.
    Feed pipe for the brew pressure gauge. This is taken from the plug in the group and is after the solenoid, so shows 0 when the group is not being used.
    Pump, auto fill controller, boiler fill solenoid, brew SSR and some steam boiler fittings in.
    Making cutouts for new front panel additions.
    More pics to follow....
    Jun 2011
    684
    The space behind the front panel starting to fill up. Faema style steam valve is in, anti vac, pressurestat, gauge and safety valve for the steam boiler.
    Wiring was probably the most challenging part of this mod, with all the components in place things were getting pretty fiddly.
    Here the temp probe and brew PID controller are in. I've also added a cold water feed back into the line to the brew boiler, the heat exchanger feed was putting in too much energy and overheating the brew boiler between shots. Bleeding some cold back in via a restrictor did the trick. Back to back stability and recovery now excellent.
    She's done! The top left switch position is now an indicator for boiler activity. Both boilers can heat simultaneously so it is properly hot in 10 minutes with a backflush or two, and draws in fact a little over 10 amps occasionally factoring in the pump.
    This is now my home machine and does the job admirably, performance is excellent and it's been going strong for a year. The only down side is the even smaller water tank, refills happen about three times a week for a few morning cuppas. A decor 1 litre drink bottle has taken the place of the original.
    Would I do it again? The sensible answer would be no, but it was good fun, and a test of what could be possible in a Silvia footprint.
    Dimal, dino, SniffCoffee and 6 others like this.
    Member ASchecter's Avatar
    Jan 2013
    USA
    98
    Very nice work
    Senior Member Lukemc's Avatar
    Oct 2012
    MILLBROOK VIC
    701
    Awesome work
    Senior Member artman's Avatar
    Jun 2006
    2,451
    Wow, that's great!!
    Oct 2013
    139
    Great work as always Rick, you are a true craftsman! I have a Sylvia V3 as a spare machine and it's amazing to see what's possible! Makes me wonder how much I can mod it with timber pieces? Hmmmm
    Apr 2012
    497
    Awesome job as always Rick, some time back in the dim-dark past I had notions of a similar upgrade, never actually got around to doing anything about it (and now my Silvia lives 800km away )
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,320
    That is sick! Love it.
    Member RayTCoffeePro's Avatar
    Aug 2014
    74
    Sick mod for the Silvia.....
    Nice looking front plate....
    Nice golden-ish grouphead
    There's a water outlet (i believe to the side)
    Wiring looks complicated and fun....
    What pump, vibe or rotary?
    I'm hoping you modded the pump....
    Mar 2012
    Bathurst
    1,181
    That's some sweet work and fabrication skill.
    Can I ask what pressure gauges they are that you are using? They look great, I could envisage them with blue backlighting.
    kbc
    kbc is offline
    Apr 2008
    2,960
    It's amazing. I have been lucky enough to see it.... Well done Rick. Great project.
    Jun 2011
    684
    Thanks all. The gauges are sourced from Expobar, they are good quality and I like the black face.
    Jun 2013
    15
    Incredibly awesome dude. Hows the steam like?
    340
    Wow! Amazing.
    What are your thoughts about using a LM stainless group handle? Seems to fit my Silvia really well.
    Would go with your LM steam knob
    Jun 2011
    684
    I mostly use a naked so the portafilter material is a moot point, but yeah why not! The stainless handles are certainly sexy. LM actually bought in alot of parts from faema in times gone by - the linea steam valve is one example.
    Jun 2006
    2,451
    this really is awesome!
    is the unit that controls the steam boiler water level a diy device or off the shelf?
    as an aside, how does a single boiler machine work on steam mode? at non steam mode water comes out of the steam wand and when temp increases in steam mode, steam comes out. where does the water go to drop the level in boiler so we get steam?
    cheers
