Results 1 to 6 of 6
Like Tree5Likes
  • 2 Post By chokkidog
  • 1 Post By DaveD
  • 2 Post By GregWormald
Thread: What Machine Next?
    Jul 2009
    6
    What Machine Next?
    My EM6910 is on its last legs, so it's time for a new machine. I am truely stuck on this decision. Do I go Pods? or do I get an EM7000?
    If I went pod, i'd be looking at this machine.
    Nespresso EN520S DeLonghi Lattissima Capsule Machine at The Good Guys
    If I replace the EM6910
    Sunbeam PU6910 Espresso Machine & Grinder at The Good Guys
    My decision is stuck because only having 1 coffee per day seems like a lot of work maintaining an espresso machine over a pod machine. And the pod machine wins for speed and convenience (insert pod, push button, drink)
    Please snobbers, give me your feedback.!!!
    Apr 2008
    Victoria, Australia
    2,095
    Before down grading your coffee to a pod, google 'pod coffee waste' and get a line on the problem.
    edit: I'll make it easier for you..... https://www.google.com.au/search?cli...GKnu8wexlILwAg
    TC and magnafunk like this.
    Nov 2013
    West Footscray, Melbourne
    212
    If you don't want to avoid pod machines from an environmental standpoint, then consider the financial. A pod contains around 5g of ground coffee, with prices ranging from 40c to 80c per pod. This gives you a per kilo cost of coffee at around $80-160/kg, for stale sub standard coffee. I say stick with freshly roasted coffee, ground on demand - the prize for which is coffee worth drinking, and you do some good for the environment and save a hell of a lot of money. You just have to decide on the fastest preparation method that suits you.
    Vinitasse likes this.
    Senior Member artman's Avatar
    Jun 2006
    2,433
    There is not much to maintaining a proper machine. If you enjoyed a decent brew from the sunbeam I doubt you will be satisfied with a pod machine. No comparison really taste wise and as above its bloody expensive.
    Jul 2009
    6
    thanks for the sanity check snobbers. I went with the EM6910. I suppose that means i have some spare parts for future too
    Jul 2007
    2,288
    I have to say that the ad linked above is a hoot!
    For instance:
    This conical burr coffee grinder operates via a twin pump and thermo block system. It has 25 grind settings and uses both pressure and precise temperature to create perfection.
    I hope that no-one who buys from them ever needs any advice
    Dimal and dmo like this.
