Results 1 to 11 of 11
Like Tree2Likes
  • 2 Post By TRRR
Thread: Water Pressure Regulator vs Water Pressure Gauge?
    Dec 2014
    Frankston, VIC
    19
    My machine is plumbed in through a tap on the mains which leads through a water filter to the machine. If I can adjust the water pressure through the tap is there any reason to go with a water pressure regulator, or will a water pressure gauge on the line to the machine suffice?
    Thanks.
    Water Pressure Regulator:
    Water Pressure Gauge:
    14,665
    Quote Originally Posted by budandbeans View Post
    My machine is plumbed in through a tap on the mains which leads through a water filter to the machine. If I can adjust the water pressure through the tap is there any reason to go with a water pressure regulator or will a water pressure gauge on the line to the machine suffice?
    Thanks.
    Use a 350 kPa PLV. Line pressure varies. The bits shown in your post will cost far more than the price of a PLV.
    Dec 2014
    Frankston, VIC
    19
    Actually water pressure gauge's are quite cheap.
    Aug 2014
    56
    You cant adjust water pressure with a tap. When the flow is zero you will still have full pressure.
    Dimal and MrJack like this.
    Dec 2009
    SYD
    497
    How are you planning to adjust the water pressure at the tap?
    Oct 2011
    1,375
    TRRR is spot on.
    Dec 2014
    Frankston, VIC
    19
    Quote Originally Posted by TRRR View Post
    Ah, fair enough. Looks like I'll be buying one on ebay than.
    14,665
    So are 350 kPa PLVs and they should be used on all plumbed machines. You should also have coffee spec. filtration in place.
    You don't spend $$$$ on gear to arse around with inappropriate connections to mains water. See our guide to filtration for some tips.
    Dec 2014
    Frankston, VIC
    19
    So are 350 kPa PLVs. Use one and you should have coffee spec. filtration in place as well.
    You don't spend $$$$ on gear to arse around with inappropriate connections to mains water. See Filtration | Talk Coffee to get you on the correct track.
    Who's arsing around? I'm still learning and if I see a cheaper option that I think will suit at the time I will go with it, however now that I'm aware I will need to invest in a PLV I will....
    So I should install it between the tap and filter?
    Oct 2011
    1,375
    Depends on the pressure rating of your filter
    Looks like the Brita C150 comes with 350kPa rated tubing, so it lools like the regulator should go upstream of the filter
    Dec 2014
    Frankston, VIC
    19
    The filter is an Everpure 2CB-GW. Working pressure is 10-125 psi (0.7-8.5 bar), non shock. So yep, before the filter. Thanks guys.
