Results 1 to 28 of 28
Like Tree8Likes
  • 2 Post By Dimal
  • 1 Post By TC
  • 1 Post By truffles
  • 1 Post By shortblackman
  • 2 Post By truffles
Thread: Please recommend me a decent tamper
    Jul 2015
    19
    Hi guys,
    I've done a few searches and have read that there's a few good brands of tampers out there. I would like to know what you guys use and what are the pros and cons of each.
    I'm a beginner and recently got a La Pavoni EL with a naked portafilter along with the basket that came with it. Correct me if I'm wrong but it's 51mm?
    I'd like to do as much research before forking out $80-$160 on something that's overkill. What I need would be something that will replace the lousy plastic one that came with the machine.
    Your help is appreciated!
    Jon
    Oct 2010
    Logan
    77
    I have and use a Pullman Barista tamper for my Bezzera Strega sized to suit my VST baskets.This is my most important equipment and ease of use is extreme
    May 2015
    21
    I have a 53mm Pullman Deluxe Tamper with Jarrah handle in the For Sale section. - $35 plus post. Not sure what the basket size is for your machine but mine was matched to a Sunbeam EM5600
    Jan 2014
    Sweden/Germany
    140
    it could be a 51 mm or 53 mm, better you look for that again.
    Senior Member artman's Avatar
    Jun 2006
    2,397
    The Pullmans are very nice, probably not a huge selection for the smaller size baskets? You could get the Pullman one mentioned above (sounds like a bargain) and get it sized to your basket for a precise fit (assuming it's too big). Pullman used to offer that service previously.
    Jul 2015
    19
    Hey guys, looks like my basket is 53mm.
    Gerry, would you be able to PM me the serial number so I can ask the guys at Pullman if they can re-size if need be?
    Jul 2015
    19
    Any other good tampers other than the pullman?
    Jul 2011
    Hobart
    346
    Eazytamp 'click' spring-loaded coffee tamper – consistent results for the professional and aspiring home barista
    16,695
    G'day truffles...
    Personally, I think you would be better off finding the time to visit one of our Site Sponsors or another reputable specialist retailer, and try out a few different Tamper designs personally, An ideal tamper for one is not necessarily the same for another as many factors are brought in to play, e.g. the size of your hand, length of your fingers, the balance of a tamper using your preferred grip, etc etc....
    A short amount of time spent on getting the best 'fit' for you, will be time will spent...
    LindaD and dan110024 like this.
    14,665
    Agreed Mal,
    The tamper chooses the hand. Ergonomics are important.
    LindaD likes this.
    Jul 2015
    19
    Thanks guys that could be the best solution. I'll look at some local shops in WA and see if I can bring my basket in and try fit
    Dimal likes this.
    Feb 2014
    Marrickville, NSW
    76
    Don't think I can put an evilbay link on here, but search for 49 58mm tamper - ships from Israel. Takes a couple of weeks, but is way better than the 'Protamp' I replaced it with, better weight overall, heaps better balance, sharper edge... The handle on the Protamp is too heavy, throws off the balance and feedback. These are both the VST 58.35mm cut.
    That said, I've ordered a nice piece of Jarrah to turn into a new handle for the Protamp base, so that should fix her right up!
    Last edited by Baref00t; 8th August 2015 at 09:39 AM. Reason: Adding correction plan
    Jan 2014
    The Dandenongs
    631
    I cant remember . does "el" represent La pav europiccola ie lever? Theyre classified as either 49mm pre millennium or 51mm post millennium. I have a Pullman barista custom fitted to my la pav professional basket for about $200. Steep, but its bloody good. Instant significant improvement, to a surprising degree.
    the $200 is forgotten, but the joy remains.
    I have done a bit of a spiel on another thread, which you may have seen. The placky tampers that ce with LP are an assault to spatial perception, so it needs to be replaced no matter what you pay.
    you used the "el" tag, so you might be talking about a pump machine? that I'm not familiar with at all
    Jan 2014
    The Dandenongs
    631
    pavoni levers only come as big as 51mm. So to get a bigger one at that priced sized to fit would be a very good option. Send it and the basket to Pullman for best results, dust of your single basket for use while the works being done (quick turnaround, my experience) & bobs yer uncle!
    Jul 2015
    19
    That's correct, it's the Europiccola Chrome. I thought it was 51mm as well when I did some research, however I checked with the ruler and it's more of a 53 mm.
    However, measuring the plastic tamper that came with the machine, it's 51 mm and it fit very well.
    16,695
    G'day truffles...
    The ID measurement you need, should be taken at about 6mm down from the rim of the basket, not across the top...
    Jul 2015
    19
    Dang! That shows how much I still have to learn!
    Update : Ok so since I only have a ruler and it's difficult to measure the basket, I thought I'd measure my plastic tamper instead as it sits flush right in the middle of the basket. It measures very close to 51mm- 51.5mm
    The edges actually are directly above the white and yellow paper, just that the shadows make it appear weirdly.
    Dimal likes this.
    Member AlastairMcG's Avatar
    May 2011
    69
    I was thinking of purchasing a cafelat tamper from the snobbery. Has anyone got experience with these? Are they good tampers for the price?
    Jul 2015
    19
    Ok guys, as I just don't have the time to shop around locally as will be busy on weekends and to save some tens of dollars only to get an inferior tamper, I just went ahead and got the Pullman Nexus!
    Reason being that I preferred the wood finish over the aluminium ones. Sending my basket over so will be making great espresso in 2 weeks or so!
    Feb 2014
    Marrickville, NSW
    76
    You won't regret it!
    Jan 2014
    The Dandenongs
    631
    Nice. I prefer the look of the nexus, but I wanted to be able to adjust the height (shorter!) so went for the barista in Australian oak.
    you won't regret the custom fit either. Well done!
    Jan 2014
    The Dandenongs
    631
    Quote Originally Posted by AlastairMcG View Post
    Yes. I've one to use with my Gaggia classic. Serves me well. Good for the price & comes with a rubber base that protects it well. Definitely good for the $$$. I got the zebra wood.
  23. #23
    May 2011
    69
    Thanks shortblackman for the reply, sounds good.
  24. #24
    Senior Member Vinitasse's Avatar
    Aug 2010
    Mornington Peninsula VIC
    1,251
    Quote Originally Posted by shortblackman View Post
    Sounds like a confession.
    Probably goes well with the Elf fort though
  25. #25
    Jan 2014
    The Dandenongs
    631
    You only have to make one or two Freudian slips around here and look what happens.
    readeral likes this.
  26. #26
    Dec 2010
    1
    I saw the cafelat tamper in Palisander, does anyone know if it's sourced from plantation / more sustainable / ethical options?
  27. #27
    Jul 2015
    19
    My Pullman Nexus arrived. It's beautiful! The quality on it is just amazing and feels great.
    Dimal and LindaD like this.
  28. #28
    Mar 2005
    2,165
    Good choice, I don't think you'll regret your decision!
