Results 1 to 2 of 2
Thread: Pressure gauge problem
    Coffee Newbie okitoki's Avatar
    May 2013
    Perth. WA
    479
    recently, I have noted my Rocket Giotto's pressure gauge (single) is slowly creeping up on the pressure reading... normally it would stay between 1 - 1.5 bar, but now its creeping up to around 2.5;
    Even when it has cooled down, it would still hang around 1.5-2; so Im thinking its more of a sticky needle? (if that is possible?) Temp seems ok, as the shots I have pulled are still consistent, and not burned even when it is showing a high pressure on the guage.
    Is it time to replace the gauge? I have also noted there are some white settlements from the hot water tap, and looks like might be some calcium being dislodged after my last service.
    thanks
    Senior Member artman's Avatar
    Jun 2006
    2,457
    Sounds like a wonky gauge and/or pipe feeding it being restricted.
    Odd that it is registering higher than your boiler pressure (presumable as the safety valve would have cut in at 2.5bar I would have thought).
    If you feel like a tinker, take the gauge out and the feed. You can test the feed pipe by seeing if you can easily blow through it. To get an old gauge going once I hooked up a tube a couple of metres long, connected to gauge and filled with de scaling solution. I kept the tube vertical to give the gauge some head pressure. Left it for a while then rinsed out with water. This fixed it.
