Results 1 to 21 of 21
Like Tree13Likes
  • 1 Post By Javaphile
  • 1 Post By Gingerman
  • 2 Post By chokkidog
  • 1 Post By yabba
  • 1 Post By sprezzatura
  • 1 Post By magnafunk
  • 2 Post By stephen28
  • 1 Post By readeral
  • 2 Post By DesigningByCoffee
Thread: Camping coffee for 17 guys
    Mar 2009
    Redlands,Queensland
    652
    Hi all need some help, next weekend going camping out bush with 17 mates and we need coffee. No power only fire and an ability to make enough coffee relatively quickly for everyone. Any suggestions would be sensational!!
    Thanks all.
    Senior Member gonzob's Avatar
    Aug 2011
    226
    I had a similar discussion in my head a while back. I didn't solve the espresso side of the equation, but I did think that to get frothy milk you could fit a steam wand to a pressure cooker, and put that on the fire. The good thing about a pressure cooker is that it is a properly designed pressure vessel with an over-pressure mechanism. I think they run at about 1 atmosphere (120C), and you have lots of room for water, so you don't run out in a hurry.The big problem is having enough milk for 18 people...
    Gonzo
    Senior Member readeral's Avatar
    Jul 2015
    1,094
    Just make a bunch of French press...
    Dec 2004
    Earth!
    15,361
    A pourover/drip, mokapot, or french press would work but they will take many pots to make coffee for 17 people.
    The only method I can think of off-hand that would brew enough over fire for that many people would be a 'cowboy pot' to either boil or percolate the coffee. The pots come in a variety of sizes from small to huge and with or with-out the percolator components. 2l is a pretty standard size but I've seen them up to 8l in size. Do a search for 'enamel camping coffee pot' on the bay of evil for examples. Outdoor outfitters should also have them on hand. Around here you can find them at places like Target, K-Mart, and Walmart as well.
    Java "Big pot" phile
    sprezzatura likes this.
    Toys! I must have new toys!!!
    May 2011
    14
    I have seen people do a 40L pour over before for a festival using large pots and a strainer with cloth in it.
    Junior Member Gingerman's Avatar
    Feb 2016
    2
    Make Cowboy coffee. It sounds all wrong, but is very good. It's full Immersion coffee without the press.
    Just don't take the last cup
    Apr 2008
    Victoria, Australia
    2,095
    I thought real cowboys used their socks as filters! :-D
    Cowboy Coffee | American Cowboy
    "According to some diaries written along the cattle trail from Texas to Wichita, cowboys would often heat the water, dump in the coffee, measuring by the fistful, and, when it was dark enough, they would pour it through one of their socks to filter out the grounds. Sugar was in high demand on the trail and was measured the same way. Yum!"
    Quote from: How to Make Cowboy Coffee: 13 Steps (with Pictures)
    gonzo89 and sprezzatura like this.
    Senior Member sprezzatura's Avatar
    Dec 2013
    Hervey Bay, QLD
    930
    Yep. Cowboy coffee. Throw the grounds in simmering water; stir and remove from the tripod. Cover. Let cool a bit then ladle it out into enamel cups with sugar nearby. It's rough but it does the job.
    I make a version in a glass called 'kopi tubruk' - you can place a saucer over the rim and invert it (carefully! Hot!) a neat camping trick: the grounds float up to the bottom of the glass and one can sip the coffee that seeps under the rim of the glass where it meets the saucer.
    Senior Member yabba's Avatar
    Feb 2009
    Adelaide
    128
    Quote Originally Posted by Gingerman View Post
    Make "Eggspresso" Essentially you make cowboy coffee but you add eggs into the grounds (cracked and then mushed in shells and all). Makes for a clean coffee as the eggs act like finnings drawing all the grounds into a goop at the bottom. I have heard that it doesn't impact on flavor.
    Second advantage is you only need to cook the bacon and breakfast is done!
    Cheers Yabba
    Dec 2013
    Hervey Bay, QLD
    930
    Oh, man - I'm trying this tomorrow. Standby for images! Cage or free-range? Gotta be free-range if it's cowboy coffee, partner.
    gonzo89 likes this.
    Senior Member magnafunk's Avatar
    May 2014
    Shepp City, VIC
    529
    I'd be inclined to say use only the egg whites. They're pretty much flavourless and we have a precedent of using them for clarifying stocks. Overcooked yolks have a very distinctive taste.
    Dec 2013
    Hervey Bay, QLD
    930
    Good point! Egg whites it is.
    Dec 2009
    SYD
    540
    Isn't tea the customary camping beverage? Definitely a lot easier to prepare for 40 ppls!
    Just get a billy and a campfire...
    Jun 2010
    139
    Generator and a Behmor Brazen Plus. Surely one of the lads won't mind slotting a generator in their kit bag.....
    mmmcoffee and sprezzatura like this.
    Dec 2011
    PRL
    2,574
    Quote Originally Posted by readeral View Post
    Yep...that is the practical solution.
    Feb 2008
    14
    Another +1 for cowboy coffee
    Dec 2013
    Hervey Bay, QLD
    930
    Egg whites and coarse ground cowboy coffee strained through a funky, wrung-out microfibre cloth.
    I wanted to simulate the sock straining technique so I used a cloth I used to wipe sweat, then rinsed it really well, wrung it out and poured the not quiet simmering coffee through it. There are no fines in the cup - the egg whites bonded with those. It's ok. A clean paper filter would make this quite drinkable in the woods. No egg taste at all.
    Dimal likes this.
    Jul 2015
    1,094
    Haha. Commitment to the cause from sprezzatura.
    Dec 2013
    Hervey Bay, QLD
    930
    Don't tell Andy: I used some of his superb Chimanimani for this experiment. I drank it all but don't recommend the wet cloth.
    Aug 2008
    Millthorpe NSW
    2,029
    How about a simple paper filter?
    Brew the billy, let the water cool a minute or two, drop in the coffee. Steep like a plunger. Most of the dregs will settle when you give it a 'plunger wiggle.'
    Then pour into the cups through a basic paper filter cone to get rid of the last few fines?
    It'll just be grinding for 17 with the Porlex that'll take most of the weekend
    Dimal and sprezzatura like this.
    Senior Member javabeen's Avatar
    Oct 2006
    496
    I'd be going full immersion method with a few big plungers. Hit up the local op shops and see if you can get some big plungers. If that fails, full immersion in a billy followed by decanting through a paper filter into another big vessel/pot.
    You could also ask your friends to bring any medium/large plungers they might have, most people have them lurking in the kitchen cupboards somewhere.
    I believe there are still plunger filters available in beanbay as well so check them out.
