Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By TC
  • 1 Post By sniferdog
Thread: ECM Mechanika IV not heating water
    May 2013
    5
    Hello Brains trust
    Have a ECM Mechanica that is a couple of years old.
    When we turn it on the pump runs for a lot longer than usual (1 minute +),
    Then the low water light indicats there is no water (it's full) and the pump stops running and the machines doesn't start the heating process.
    Doesn't always play up but will on occasion start ok
    Probably not an easy fix but any help appreciated in advance
    Dec 2011
    PRL
    2,519
    What water are you putting in the tank?
    May 2013
    5
    I have used filtered water since day 1
    Dec 2011
    PRL
    2,519
    Quote Originally Posted by sniferdog View Post
    Filtered by what method? That is my point. This might explain why the machine is not detecting the correct water level.
    16,443
    Quote Originally Posted by Barry O'Speedwagon View Post
    May be due to scale buildup on the probe surface if the filtering process is inadequate.... Possibly B.O'S's point.
    May 2013
    5
    ok understand. I've been using a Brita jug filter. I realise this is not ideal however I try to descale every 4 or 5 months. Maybe this is not enough?
    May 2013
    5
    Yes ok. Sounds like the issue. Given this is probably the problem can I locate this and clear or is this a back to base fix?
    14,665
    My thoughts are that in all likelihood, you have a combination of issues here. I would advise you have the machine looked at by a professional.
    Descaling? Best not unless you are certain it's required. Should I descale my machine? | Talk Coffee
    We service machines which have been backflushed with descaler, descaled with backflush detergent and fwiw, the overwhelming majority of descale treatments done to machines are either not required or completed incorrectly. Owners frequently do more harm than good.
    Dimal likes this.
    May 2013
    5
    Chris, Dimal and Barry thanks for taking time with the advice. Very much appreciated
    Dimal likes this.
