Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Gavisconi007
Thread: Espresso machine water tank cleaning and water refreshing
    Apr 2010
    155
    Hello.
    Those with espresso machines like Rancilio Silvia or gaggia classic which are not plumbed into water pipes I have water tank maintenance question.
    How often is it recommended to empty tank from existing water and refill tank with 100% new water?
    Every day? Every other day?
    Senior Member skidquinn's Avatar
    Oct 2015
    Brisbane
    144
    Hi there
    I make approx. 4-6 coffees a day on my Silvia and find I need to top the water tank up almost every time I use it. I only remove the tank and clean and refill probably every 2 or 3 weeks.
    16,442
    I remove mine once per year at the same time as I do my annual service/maintenance on the espresso machine. Never been a need to do it more often than this, with using high quality filtered water...
    Apr 2010
    155
    Thanks, I replace all tank water every 24 hours and clean water tank every 7 days. Am I overdoing it then ? I was concerned about stale water in the tank growing various nasty bacteria etc.
    May 2010
    Sydney North Shore
    1,325
    I double filter the water I use and rarely replace the water or clean the tank. Perhaps I should do it more often.
    Bacteria and algae cannot grow in pure water as they have nothing to feed on.
    If the water inn your tank looks impure or dirty, chuck it out and clean the tank. The main test is how does your coffee taste. Most bugs will be destroyed by the heat of the boiler.
    Enjoy your coffee.
    Barry
    16,442
    Quote Originally Posted by acid_rider View Post
    Individual circumstances probably vary quite a bit so if you think your water tank needs cleaning, there's nothing wrong with cleaning it every day if that makes you happy....
    Senior Member Gavisconi007's Avatar
    Mar 2014
    574
    I'll go out on a limb and say yes, you're over-doing it. No-one ever cleans the inside of their water-pipes in their house and many drink tap-water with no problems. If you're using your coffee machine daily then the tank is getting flushed through with fresh water and the water is boiled anyway
    Mal's birthday bubble bath for Sir Kony is all that's needed.
    Dimal likes this.
    Senior Member artman's Avatar
    Jun 2006
    2,333
    If you can feel/see the walls of the tank are unclean in anyway when you clean it, shorten the cleaning interval.
    16,442
    Quote Originally Posted by Gavisconi007 View Post
    Indeed...
