Results 1 to 4 of 4
Thread: Storing / Emptying a Silvia
    Mar 2005
    18
    Hi Guys,
    Just wondering if anyone knows how I can drain the boiler of a Silvia as I am storing it for approx 6 months. Does this involve opening the machine?
    Lastly, am i better off leaving it or is 6 months too long for it to sit around full off water.
    Aug 2004
    2,312
    Re: Storing / Emptying a Silvia
    Hello Newbean,
    I would simply run a "regular" descale cycle first, then put it away.
    The boiler is made of brass so it wont corrode, shouldnt be a problem. Many new machines sit for longer periods after manufacture and before sale to the end user, and they all have water in.
    Or you could ofcourse, lend it to someone *:)
    More specifically to your question however...
    It is important to note that even if someone were to advise how to drain the boiler, you would need to be well aware that if you subsequently forget, to refill the boiler BEFORE switching the machine back on electrically (ie when it eventually comes out of storage), it would result in failure of the electric element (from being energised when dry) and requirement for subsequent expensive repair
    I therefore wouldnt do it.
    Regardz,
    FC.
    Mar 2005
    18
    Thanks FC,
    I appreciate the advice. When you say descale cycle, do you mean run a descaler through it, give it a good flush and let it be? This would probably be a good idea as my friend (who I borrowed it from and will be storing it for) used tap water.
    Aug 2004
    2,312
    Yes,
    FC.
  1. Emptying the boiler on a Grimac La Uno
    By nico in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 15th January 2011, 04:28 PM
  2. Storing a BZ99
    By jimandlet in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 17th December 2010, 07:42 PM
  3. Storing Silvia
    By Shimmy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th March 2009, 06:18 AM
  4. Emptying silvia boiler
    By MattG in forum Brewing Equipment (non-machine specific)
    Last Post: 9th June 2006, 09:21 AM
