Results 1 to 3 of 3
Like Tree3Likes
  • 1 Post By herzog
  • 2 Post By Dimal
Thread: Drain hose
    Sep 2007
    Northlandia
    1,365
    Drain hose
    So, Ive finally bitten the bullet and ordered an under-bench water filter; also picked up a drain box for the drip tray. It has what looks like a standard irrigation hose bayonet style outlet; I have some spare black poly hose I could probably use, but it's difficult to bend in a tight radius and due to the run will be visible on the bench.
    Any suggestions for what to use? Something that can be bent in a very tight curve would be ideal, as I could then encase it and the water inlet hose through some conduit to keep it tidy.
    Dec 2009
    SYD
    496
    Clear pvc tubing is commonly used. Comes in a range of diameters although I think many machines use 13-15mm.
    Magic_Matt likes this.
    16,433
    Perhaps look for suitable 'elbow' fittings...
    Brewster and Magic_Matt like this.
