Results 1 to 10 of 10
Like Tree6Likes
  • 4 Post By mjs
  • 1 Post By boren
  • 1 Post By Dodgy-Account-Grillsy
Thread: What a Difference 0.5mm in Tamper Diameter Makes
    mjs
    mjs is offline
    Dec 2007
    75
    Have had my Expobar Minore III for about three years now, bought second hand, also have a Macap M4D, mixture of espresso, cappucino and lattes, but usual coffee is a double shot latte, mainly used on weekends. Generally pretty happy with results.
    I have been using a couple of stock 58mm tampers, and just recently decided to get a 58.5mm flat base Pullman Nexus tamper as there is a bit of slop between the baskets and the 58mm tamper.
    To say I am pleased with the improvement in shot quality is an absolute understatement. Beautiful darker caramel stream, thicker, better crema and flavour is up a significant notch. I guess its just being able to ensure that the puck is compacted fully to the edge of the basket, so that there is an even permeability across the puck and no channelling. Definitely recommend this as an upgrade. The Pullman has a walnut handle, so its a nice looking tamper as well!
    Any other CS’ers have this experience?
    Brewster, geoff, matth3wh and 1 others like this.
    Banned
    Jan 2018
    100
    You’re not alone buddy.
    I had similar experience and noticed much more consistent extraction time from shot to shot after going from a stock tamper and basket to a 58.5mm tamper and matched basket. I suppose the extra 0.5mm stops water flowing down one side more that the other.
    GR
    Aug 2018
    Israel
    23
    I always had suspicion that the 0.5mm makes a difference. Now I can use this as an official excuse for my less-than-perfect shots ;-)
    Time to look for a new tamper...
    matth3wh likes this.
    Jun 2007
    132
    I'm a bit bummed to hear this. I've been using my Coffeelab 58mm tamper for years and love it. But now I've got 58.5mm baskets and needs new tamper.
    mjs
    mjs is offline
    Dec 2007
    75
    You know you need a 58.5mm tamper :-))
    Jun 2007
    132
    Quote Originally Posted by mjs View Post
    Yes, AFTER I got the baskets. They came with my new machine. Kabish?
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    928
    How about a 58.4mm tamper so it fits just inside your 58.5mm basket 🤡
    mjs
    mjs is offline
    Dec 2007
    75
    Well, I thought I had “standard” baskets and had a couple of 58mm tampers which were also “standard”. Not sure if the baskets were a standard 58mm or not but the tampers were loose in the baskets and it was obvious that a larger tamper would be a closer fit. Maybe it’s just what a standard basket is like.
    Junior Member Papanick's Avatar
    Jun 2018
    8
    Does a 58.5mm tamper fit in the standard baskets that would come with a machine, or do you need to buy a matching basket?
    Banned
    Jan 2018
    100
    Quote Originally Posted by Papanick View Post
    Hey there. My 58.5 tamper fits the standard baskets. They must be 58.6 .7 .8 ish.
    GR
    Papanick likes this.
