Results 1 to 8 of 8
Like Tree4Likes
  • 1 Post By micsam2106
  • 3 Post By Steve82
Thread: Force Tamper
    Dec 2010
    16
    Force Tamper
    Hi i am just wondering if anyone has used the "Force Tamper" calibrated tamper and if they have any opinons on it. I have a Pullman but looking to buy a calibrated tamper also.
    Regards Michael
    matth3wh likes this.
    Apr 2016
    78
    Is it the $250 tamper from coffeeparts you referring to? If so, probably a bit too much for a tamper?
    I've seen similar from tough coffee (Chinese brand) at $70 mark.
    Nov 2013
    1,110
    Quote Originally Posted by sharkroman View Post
    Does that one click when the preset downward pressure is reached or retract back upwards away from the coffee? The force does the latter, which actually sounds like it might work. The click ones only ensure you are tamping at least the preset pressure and usually significantly more.
    Jul 2018
    fairly static
    186
    That depends on the quality of the item. Click-release is used for high precision torque wrenches (and low quality ones too).
    Feb 2012
    Central Coast NSW
    673
    It is the end game of tampers, especially if the user has any ailments in hands / wrist.
    Ive had many tampers over the years, cheaper ones, good quality / value like cafelat, pullmans and pergs, barbers and barista hustle. I got the force from coffeeparts on pay later and will not ever return to a normal tamper.
    I get a perfect level tamp with the same force applied everytime without any effort, so easy it can be done with one thumb.
    The tamper used kinetic energy from a loaded spring. As one pushes down slowly compressing coffee right at the end of piston stroke it releases the required enegy into the puck. The amount of force is easily adjusted.
    It allows more time for care to be taken with distribution of coffee in the filter basket. Im glad to have removed tamping variable from espresso prep.
    matth3wh, topshot and beensean like this.
    Dec 2010
    16
    Do you kow what the max pressure the force tamper can provide?
    Feb 2012
    Central Coast NSW
    673
    Quote Originally Posted by micsam2106 View Post
    About 10 to 18kg
    Aug 2018
    Israel
    23
    I'm convinced its a better tamper than anything else, but not convinced the improvement over what I already have today (which works well) is worth so much money. In fact, I'm not even sure I'd pay half of what they're asking.
