Results 1 to 9 of 9
Like Tree7Likes
  • 1 Post By beensean
  • 1 Post By FilthySudo
  • 1 Post By level3ninja
  • 4 Post By Yelta
Thread: Distribution tool or no?
    Jul 2018
    Brisbane/Sunshine Coast
    88
    I know this has been noted a few times but I have read through these and still indecisive.
    I currently measure my coffee ground into my portafilter and then use a toothpick to mix the grounds up to reduce clumping and make it a bit fluffier prior to tamping.
    should I pick up a cheap distribution tool off fleabay or spend a bit more on a decent one? Or just not worry with getting one at all?
    just wanting to cut some time down when doing this step and trying to weigh up if it's worth the $20-100 purchase
    Apr 2007
    386
    i purchased one of the cheap ebay ones and cant say i have noticed any huge difference using my naked portafilter
    Jul 2018
    88
    Quote Originally Posted by JohnA View Post
    That's good to know! Did you do anything prior to buying the tool? Like regards to break G up the grounds or anything of such?
    Jul 2018
    fairly static
    197
    Quote Originally Posted by FilthySudo View Post
    ... use a toothpick to mix the grounds up to reduce clumping and make it a bit fluffier prior to tamping.
    My problem was quite different. The grounds are so fluffy from the NicheZero that I need to spread them down a bit along the way so I do not lose spillage. After tipping in about 2/3 - 3/4 of the grounds, I spin the distributor on them then add the remainder before spinning again. My principal purpose is to make some room for the remaining grounds, then ready for tamping; clumping has not been an issue.
    should I pick up a cheap distribution tool off fleabay or spend a bit more on a decent one? Or just not worry with getting one at all? just wanting to cut some time down when doing this step and trying to weigh up if it's worth the $20-100 purchase
    I read about the 2-arm (chisel), 3-arm, and 4-arm distribution tools, including the claims by Ona, before settling on a chisel tool. It simply makes more sense mechanically in terms of distribution rather than unwanted tamping. The options I found were not in your price range. I have been very happy with the Pullman though.
    NJD likes this.
    Jul 2018
    88
    Quote Originally Posted by beensean View Post
    Ohh without a doubt if I didn't mind spending more than I spent on my tamper it's self for an ocd chisel or pullman then I definitely would. Absolutely love my pullman nexuspro.
    This coffee game is an endless pit of money as I find myself constantly buying more and more little things
    steve7 likes this.
    Feb 2012
    Brisbane
    139
    Roger that!
    Nov 2013
    1,289
    I have a fleabay one I bought a couple of years back. When I bought it I was using a Breville Smart Grinder, and it noticeably eliminated the occasional awful shot and slightly improved my worst shots. Since getting a Eureka Atom a bit over a year ago it's become useless. I see no improvement from it at all (no awful shots and my worst is still decent), so it's been in a drawer for quite a while.
    Dimal likes this.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,730
    Good technique will triumph over gadgets every time.
    Dimal, JohnA, Mono and 1 others like this.
    Junior Member Hughie's Avatar
    Jul 2018
    CQ
    29
    Just stockfleth that puppy!
