Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By CafeLotta
Thread: Easy removal of Portafilter baskets
    Jun 2012
    Melbourne, Vic, Aust.
    991
    Came across this tip a while back which makes removal of tight Portafilter baskets really easy. Thought I'd post it for those who haven't heard it before.
    The beginning of this video shows how to easily lever out a basket. The blind is ideal for doing this. If its really tight, you may need to swap side to side on the portafilter lugs.
    https://www.youtube.com/watch?v=1mC7jGiKYtw
    Apr 2007
    386
    just take the spring clip out
    Nov 2017
    Maddington, Perth. Wa
    864
    Mine was soooo tight. I bent the straight sections of the clip to make it easier to get the baskets in and out. Pita without a clip, imo, everything falls apart.
    Jun 2012
    991
    I think I prefer a tight fitting basket to having it knock out with the grinds and the resulting mess.
    I came across a lighter spring clip for my portafilter but think they are pretty much a universal fit for 58mm basket portafilters.
    The thinner one - https://www.coffeeparts.com.au/parts...1-1mm-diameter
    Slightly thicker (standard?) but there is a difference - https://www.coffeeparts.com.au/parts...1-2mm-diameter
    I bought both a while back to compare and there is a visual difference in thickness and the thinner one makes for easy basket removal in my portafilter (VBM).
    Dimal likes this.
