Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By LouisF
Thread: Lubrication of cam in E-61
    Sep 2016
    The Strand, Western Cape Province, South Africa
    27
    I have read posts on other forums, describing how to open up an E-61 brew head to apply lubrication to the cam lobe's. I have also seen more than one Youtube video demonstrating how to do this. I wrote to the chief supplier of my machine (Expobar) in South Africa to source the appropriate lubricant and making sure if this is a requirement. The answer I got was that the machines arrive here with no lubrication on the cam. The reason is actually quite obvious: the hot water passing through the head will wash the lube away. What however does need lubrication is the shaft of the cam. This is done by taking the valve apart - as per the videos that shows how the cam should be lubricated - push the cam off the shaft and lube the shaft. Put that assembly together, assemble the valve and Bob's your uncle. Make sure to use a lubricant that is food grade, like Weicon silicon grease, for instance.
    Mar 2012
    Bathurst
    1,227
    Is this a question?
    Sep 2016
    27
    No, information to share.
    gordons likes this.
