Results 1 to 5 of 5
Like Tree5Likes
  • 1 Post By towe0609
  • 2 Post By kofekitt
  • 1 Post By LeroyC
Thread: Boema 2 group lever
    Sep 2005
    129
    Boema 2 group lever
    Looks like I'll be picking this up this afternoon. The text with the add read "Rather stylish vintage 2 group vintage lever pull coffee machine. Was working in family cafe, then in storage for years. Plugged it in this morning, boiler is working fine, leak coming from the left hand group head. Will need gaskets."
    I'll likely repair (not restore), play with it for a while (I've never had a lever before), and then decide whether I want it in my life long term. I'd be interested to know whether there is a strong market for these in running order should I decide to move it on and what I might get ... I need to set a repair budget!
    If anyone has any information about it (model, era, boiler details etc) I'd be grateful.
    matth3wh likes this.
    Jul 2009
    221
    Hi , looks like a fun project. If it's been sitting for years, groups will most likely need a full rebuild, not just seals. The groups are based on Astoria/CMA lever group, but even that has changed a few times over the years, so check you're getting parts for the earlier version . Boema the company is still going, and from what i've heard they are very helpful with parts if available for these old machines.
    As for re-sale - it's a tough one, it's way too big for most people at home, but cafes don't want them either . I always try and get single groups if possible.You may be lucky and get someone with a coffee cart or similar who wants it, but then it would need gas install and full rebuild...
    https://coffeesnobs.com.au/brewing-e...d-madness.html
    matth3wh and towe0609 like this.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,039
    Rick Bond ‘The Coffee Machinist’ is the man to talk to about this one. He has a certain affection for old Boema levers. Boema themselves are good to deal with but I can tell you now they won’t have parts for this other than maybe gaskets and o rings.
    towe0609 likes this.
    Sep 2005
    129
    I'm in trouble ... broken rusty bolts /studs between group and boiler.
    There is a part (I don't know what to call it) between the boiler and the lever group. It seems connected to the boiler by a huge nut (about 43mm if I recall), and to the group by 2 bolts (top) and 2 studs (bottom).
    What happens if I undo the huge nuts between the boiler and this part attached to the group ... will that separate it from the boiler at least .... I'm hoping there will be enough room to jenga it free from the face plate, and can I at least then take the group to a machine shop to drill the bolts out. You cannot get at them from either side until the boiler and group are separated.
    Sep 2005
    129
    I got 1 out of 8 bolts / studs out between the group and boiler flange ... the rest were corroded in and got drilled out to be replaced with M10 stainless hardware. I managed to remove the boiler flange (I don't know what to call it) from the boiler via the compression fittings. They were very tight, but a bit of tap tap on the shifter on the big nuts got them loose and I was able to separate the boiler and groups which then provided access to the flange faces to drill out the corroded fasteners. I was very thankful, as they would have been the end of the project.
    Does anyone know if these old Boema lever groups are sleeved? I read that they are based on CMA/Astoria groups (which are sleeved) but I don't think my groups are ... if they are its very difficult to spot. I have 'pushed' carefully (but with some force) on the shower screen end of what would be the inner sleeve and it didn't budge. Unless I can be convinced, I'm going to clean up the group as is.
    There appears to be very little information around specifically about Boema lever machines.
    Now to tackle the boiler and valves ... I hope the worst of it is behind me, but I fear not. I'm not game to order anything for the rebuild until I can get it all apart without breaking anything I cannot replace.
    level3ninja likes this.
