Results 1 to 14 of 14
Like Tree16Likes
  • 6 Post By beensean
  • 1 Post By LeroyC
  • 1 Post By deegee
  • 4 Post By noidle22
  • 1 Post By beensean
  • 3 Post By deegee
Thread: What came first? The coffee or the milk?
    Member SunnyCoastDazza's Avatar
    Mar 2019
    35
    Newbie question. Single boiler machine. Would one froth his milk first prior to pulling a shot or vice versa and why?
    Jul 2018
    fairly static
    197
    Which one do you feel less concerned about it going flat?
    When I owned a single boiler machine, for many years, my solution was coffee then milk for the following two reasons:
    1. I found it quicker and easier to control the espresso temperature by doing coffee then heating for milk, rather than cooling for the coffee.
    2. Given that the milk is the bulk of the liquid for most coffees past a macchiato, having the milk temperature correct at the point of serving made it more likely that the final drink temperature was right.
    ymmv
    bosco, Dimal, greenman and 3 others like this.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,359
    Definitely coffee first.
    rossross likes this.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,247
    Yep! coffee first.
    Senior Member deegee's Avatar
    Sep 2012
    Brisbane Southside
    349
    Quote Originally Posted by SunnyCoastDazza View Post
    Hi all, Newbie question. Single boiler machine. Would one froth his milk first prior to pulling a shot or vice versa and why?
    Are you asking in regard to your Gaggia Classic ??
    SunnyCoastDazza likes this.
    Senior Member Rocky's Avatar
    May 2008
    Central Queensland
    1,160
    When I do coffee, I generally do a Long-black for myself and a Flat-white for my Son.
    Like Beensean, I am thinking about what is going cold while I complete the process (which is a bit longer for a single-boiler).
    I pull the shots first. The shot for the Flat white isn't a problem because it is getting the hot just-steamed milk into it immediately before serving, however my Long black is sitting on the counter going cold while I finish the Flat white. I deal with this by putting an insulated coaster on top of the cup and wrapping a teatowel gently around it. This leaves it at perfect drinking temp when I'm finished the process.
    Mar 2012
    Bathurst
    1,207
    Bond has an interesting technique
    Dimal, Yelta, woodhouse and 1 others like this.
    Jun 2009
    Moonta SA.
    7,247
    Quote Originally Posted by noidle22 View Post
    He certainly does.
    Mar 2019
    35
    Quote Originally Posted by deegee View Post
    Yes mate. What ya reckon
    Senior Member Erimus's Avatar
    Mar 2014
    Kippa-Ring Qld
    406
    This outfit recommend steam first.
    https://www.wholelattelove.com/blogs...before-brewing
    Jul 2018
    fairly static
    197
    My machine for 12 years was a Rancilio Silvia, which performed as it should without a problem. Of course I rinsed out the steam wand immediately after use, thereby also reducing the boiler temperature for longevity. However, their points about temperature accuracy look difficult to achieve or verify. That about temperature surfing bears little resemblance to any other description of the process I previously read, all those being based on a cresting temperature rather than catching a falling point.
    WLL was a key source for me back when I bought the Rancilio. In that context, I think their linked advice a bit daft. Note they do not address final drink temperature at all.
    Sep 2012
    Brisbane Southside
    349
    Re your question - coffee first, then milk.
    A couple more tips :-
    One is to start steaming the milk before the "ready to steam" light comes on. If you wait for it, then begin steaming, the power to the elements will be off, and you are relying on the residual heat of the boiler to generate your steam. The pressure will drop quite noticeably as you steam.
    The time from steam switch on to light on (and power off) is pretty consistent. From my very rusty memory it's about 40 seconds. So if you start steaming after about 30 secs, the power stays on while you steam and keeps the pressure up. When you get it right, the light will come on just before you are finished.
    The Classic has a very small boiler, and the water temp will drop during the shot, Depending on the thermostat dead band, it may be only just hot enough at the start, and well below optimum by the end of the shot. This can result in sour shots with some beans. It can be partly offset by flicking the steam switch on/off for a few seconds just before your pull a shot. There is a good post about this by sponsor Rick Bond :- https://coffeesnobs.com.au/brewing-equipment-non-machine-specific/32931-some-visual-data-single-boiler-temp-surfing.html
    If you think that your shots are a bit sour, it could be worth looking into.
    Mar 2019
    35
    Cherz mate, will look into that. I’m currently waiting on my m2m to have a play. I’m more of an espresso/ longblack guy tbh. I saw this bloke on YouTube heat up his gaggia for a shot. Then he flicked on the steam button for 20 seconds prior to pulling his shot. It seems that there is a lot of “tricks” with the little gaggia
    Feb 2018
    Toowoomba
    3
    This is a great idea thanks. I’ve currently progressed from a em6910 and em7000 to a Lelit Anna with PID. I’ve been mulling over the chicken and egg question myself. I tried steaming the milk first this morning, but it seemed to separate by them time I’d finished the shot. I’m also a bit slow while I get the hang of new system. I’ll try this tomorrow morning.
