Results 1 to 21 of 21
Like Tree22Likes
  • 4 Post By ermat
  • 3 Post By ermat
  • 1 Post By woodhouse
  • 3 Post By Jackster
  • 1 Post By simonsk8r
  • 1 Post By matth3wh
  • 2 Post By Jackster
  • 3 Post By MrJack
Thread: First VST result
    Apr 2019
    NZ
    29
    First VST result
    For what it is worth here is my first VST coffee.
    My cridentials. Absolute novice !
    I recently purchased a 20g vst ridgeless basket and a jetblack flat 58.35 tamper. (reasonably snug fit, but some wigggle room)
    Adusted my grinder down 3 steps finer from my original rocket basket setting and measured out 20g.
    Flow rate was too slow at around 45 seconds so I will shift my grind 1 notch coarser next time.
    Anyway it was the best flavour I have had from this bean, richer, smoother, great !
    Puck looked good, no channeling. So my concerns regards comments about the vst being difficult to master were not the case. So far so good.
    Nov 2017
    Maddington, Perth. Wa
    991
    Yes, they are awesome.
    You should consider to buy/beg/borrow a bottomless portafilter, so as to check your work. There may be taste improvement also.
    16,978
    Quote Originally Posted by ermat View Post
    So far so good.
    More importantly, how did it taste?
    Apr 2019
    NZ
    29
    Like I said above
    Dimal, CafeLotta and woodhouse like this.
    Senior Member woodhouse's Avatar
    Dec 2016
    325
    my experience with vsts too. they let the water flow through faster, so you have to grind finer to get the same contact time, and the higher extraction gives you a tastier cup.
    speaking of, scott rao's new trick with the aeropress filters let the water flow through faster too, so you can do another tighten up for an even higher and tastier extraction. people with good grinders and decent machines are hitting 26-27% now.
    matth3wh likes this.
    Nov 2017
    991
    Linky Woodhouse, you teaser...
    Nov 2013
    1,562
    I found this photo https://i.imgur.com/RxYUepM_d.jpg?ma...idelity=medium and this post https://www.instagram.com/p/Bw7JZFSnCeb/?hl=en. The first photo is from Reddit so I don't know if it's Scott's or not.
    Apr 2019
    NZ
    29
    wow ! So would the grind need to be coarser with the filters ? My cridentials. Absolute novice !
    Nov 2017
    991
    I found a hb thread about it. Seems like the suggestion is a 10-20 micron filter paper, and a aeropress filter on top.
    Nov 2013
    1,562
    wow! So would the grind need to be coarser with the filters? My cridentials. Absolute novice!
    According to the comment in the link (emphasis mine):
    Six or seven years ago my friend @soyboyandy told me he had been using an aeropress filter under his espresso pucks to absorb fats and cholesterol. Andy reported the interesting side effect that the filter allowed him to grind finer and extract (1.5%?) higher.
    Oct 2009
    Geelong
    1,097
    Quote Originally Posted by woodhouse View Post
    Wwwow.... that is fascinating... especially about the top filter greatly eliminating channelling which is indeed significant.... I feel some experimenting coming up!
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    982
    Quote Originally Posted by simonsk8r View Post
    Yep. Well worth looking in to and testing for yourself to see if you like the end result in the cup.
    Will be testing additional filters on Robot at work and home machine.
    simonsk8r likes this.
    Nov 2017
    991
    Good utilisation of my aeropress filters, considering I use a metal one for aeropress.
    The HB thread I saw was here:
    https://www.home-barista.com/espress...ck-t58544.html
    matth3wh and simonsk8r like this.
    Oct 2009
    Geelong
    1,097
    Quote Originally Posted by matth3wh View Post
    Quote Originally Posted by Jackster View Post
    Awesome, thanks guys, can't wait to try it
    Oct 2011
    1,376
    Just wanted to point out, Scott Rao might have just started talking about it, but there were home baristas experimenting with the exact same idea in 2015, if not earlier...
    Edit: Make that 2011, if not earlier...
    Dimal, matth3wh and simonsk8r like this.
    Apr 2019
    NZ
    29
    [QUOTE=MrJack;651374]Just wanted to point out, Scott Rao might have just started talking about it, but there were home baristas experimenting with the exact same idea in 2015, if not earlier...
    Edit: Make that 2011, if not earlier...[/QUOTE
    Do you have a link to the earlier experiments ?
    Oct 2009
    Geelong
    1,097
    ......... I tried just the Aeropress filter on the top of the puck this morning for my espresso..... wwwwow. Absolutely blown away, and the difference was actually really noticeable.
    I might make a thread about it tomorrow after I try it again.
    Jul 2009
    Mid North Coast NSW
    982
    First VST result
    The other up shot of a paper filter on top is it might stop the early death of many machines and save the clogging of many shower screens round the world.
    Oct 2009
    Geelong
    1,097
    The other up shot of a paper filter on top is it might stop many save the clogging of many shower screens round the world.
    Haha true.
    Also Sprometheus did a recent video on using the filters in a few ways, and used a refractometer too. Just a quick casual experimental vid which was cool to see. The discussion happening in comments below the vid are interesting too
    Oct 2009
    Geelong
    1,097
    Also @matth3wh, TOTALLY irrelevant to the topic, but I'm currently wearing a shirt I got back in my GJ days, and it looks similar to your avatar pic haha, just a funny fact XD
    Jul 2009
    Mid North Coast NSW
    982
    First VST result
    Nice one! Iíve got a Make Coffee Not War T shirt for winter time.
    Token bringing back on topic ;-)
    VST plus filter paper seems pretty tasty.
    Tested several with robot at work. Less channeling. Tasted great.
    Shot quality improvement on home machine.
    Would love to see this in action on one of the transparent port filters.
    I will do a cafetto clean on home shower screen then see what it is like after a week of filters on top.
