Results 1 to 22 of 22
Like Tree20Likes
  • 3 Post By CafeLotta
  • 1 Post By Yelta
  • 1 Post By Dimal
  • 1 Post By Jackster
  • 1 Post By Mb21
  • 1 Post By Hoggy42
  • 2 Post By Dimal
  • 2 Post By level3ninja
  • 1 Post By Hoggy42
  • 3 Post By Hoggy42
  • 2 Post By CafeLotta
  • 1 Post By ermat
Thread: Making a portafilter gauge?
    Senior Member Hoggy42's Avatar
    Dec 2017
    110
    Hi Guys,
    Any chance there is a how to build thread on the forum here? where and what to buy
    I'd like to check my pressure
    Jun 2012
    Melbourne, Vic, Aust.
    1,270
    From another thread -
    "If you're ever looking for a good quality Pressure Gauge for OPV adjustment or troubleshooting, I can recommend one from Edesia Espress which cost around $45 landed from the UK.
    They're Certified and more solidly built than the plastic bodied ones. If you search "Edesia Espress Portafilter Pressure Gauge" you'll find them."
    Remove the spout from your existing portafilter and attach gauge temporarily for pressure testing.
    Paolo, Yelta and Hoggy42 like this.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,247
    Quote Originally Posted by CafeLotta View Post
    If I were in the market for a gauge this is the way I would go, inexpensive, easy and from what Cafelotta tells us, a quality unit.
    Hoggy42 likes this.
    17,415
    I'd also suggest utilising a Blind Filter to fit the hardware to rather than the Group Handle, as then the end result can be used on a multiple of 58mm filter spec'd machines - In case some friends need your assistance...
    CafeLotta likes this.
    Nov 2017
    Maddington, Perth. Wa
    1,073
    I agree mal, but then I was thinking that it's not useful unless the friend has a naked portafilter.
    At least it seems most (a few?) portafilter threads are fairly standard.
    Dimal likes this.
    Oct 2016
    Central Coast NSW
    381
    Hi Hoggy42
    have a look at this thread, it may help. I used Greg’s gauge and it helped
    http://coffeesnobs.com.au/brewing-eq...auge-road.html
    Dimal likes this.
    17,415
    Quote Originally Posted by Jackster View Post
    Yep, that's true enough mate.
    I guess I was just thinking that naked PFs seem to be almost ubiquitous these days, but of course, they're not...
    Nov 2017
    1,073
    My thoughts too. That's why I have both setups!
    Dec 2017
    110
    Thanks guys top advice there.
    I don't have a naked portafilter I would like to get one in future. I did however pick up a 2nd portafilter really cheap a VBM which fits the expobar as expected and as luck would have it came with a 20g VST basket.
    I've had this machine for around a year it has no gauges what so ever the previous owner tells me it was serviced before I got it but since then has had a new pump and other bits so I doubt it's going to be running at the correct pressure.
    the other question that came up while researching this pressure gauge is some people are putting a tap on the end to simulate a pour is this important for setting the pressure or just misinformed?
    Nov 2017
    1,073
    Mine just leak a bit.
    level3ninja likes this.
    Dec 2017
    110
    I've ordered the unit that
    Cafelotta suggested.
    Jun 2012
    1,270
    Quote Originally Posted by Hoggy42 View Post
    If you ordered it on EvilBay, just be aware there were 2 postage options.
    The standard economy option currently shows delivery "Estimated between Mon. 17 Jun. and Mon. 23 Sep".
    The slightly more expensive tracked option shows delivery "Estimated between Tue. 18 Jun. and Fri. 5 Jul."
    I think mine took around 3 weeks but I can't remember which postage option I had.
    Dec 2017
    110
    I did and it's on the slow option I figure I've been using it for months this way I can live with it a bit longer.
    17,415
    some people are putter a tap on the end to simulate a pour is this important for setting the pressure or just misinformed?
    It is a more accurate way to do things but not essential.
    Simulating the flow rate for the way you like to pulls shots, ensures that what you record is optimum for you.
    Without an adjustable valve, you need to set the OPV so that your brew pressure reading is about 1.0Bar +/- 0.25Bar higher than than the so-called ideal of 8.5-9.0Bar...
    That will get you very close.
    CafeLotta and Hoggy42 like this.
    Nov 2013
    1,834
    If it's brass I'm happy to convert it to naked for nothing, you pay postage both ways.
    Dimal and Hoggy42 like this.
    Dec 2017
    110
    pretty sure it's stainless. I will however keep your offer in mind should I get another cheers
    Oct 2016
    Central Coast NSW
    381
    If it’s stainless find a machine shop / place with lathe and it’s a really quick job. Make it even quicker by taking the portafilter off prior, may need to heat it up the break / melt the threadlocker if it was used.
    If you get stuck let me know
    Dec 2017
    110
    Just an update the gauge arrived today from the UK I only requested the slow post option. I have not had the chance to set up and run a test yet but will this weekend should be good to see where it's at.
    Dec 2017
    110
    I probably should have called the thread (Where can I buy a portafilter gauge)
    Anyway I had the chance to check the pressure on my Expobar Office today I bought this machine about a year ago being told it had just been serviced. A few months back I had some issues which lead me to replace the pump and some other parts, this entire time I have been blind as to what the pressure might be. Having the gauge on this morning revealed it to be running over 14bar a few minor tweaks of the OPV later and 10bar and quite a noticeable change in the result in this mornings brew.
    Such a simple tool for peace of mind I'm sure it will be handy for the Isomac rebuild as well.
    Dimal, CafeLotta and level3ninja like this.
    Apr 2019
    NZ
    29
    Not doubting you for a moment Mal but as I'm also about to make an OPV adjustment on my recently aquired giotto can others confirm my gauge reading at the portafilla will actulally be reading 1 bar lower than reality.
    Jun 2012
    1,270
    Quote Originally Posted by ermat View Post
    With respect, asked and then answered by one of the Forum's Oracles.
    Yelta and 338 like this.
    Apr 2019
    NZ
    29
    Point taken ��
