Results 1 to 10 of 10
Like Tree15Likes
  • 9 Post By Meggs8
  • 1 Post By Jackster
  • 5 Post By Meggs8
Thread: Brew scale stand
    Junior member
    Dec 2010
    Paynesville, East Gippsland
    27
    Brew scale stand
    For those who like numbers and find scales a help in chasing good espresso.
    I find scales are a great help in dialling in my grinder and playing with extraction but I was sick of trying to dry them off after the relief valve flooded everything at the end of a shot. I then learnt about a nifty gadget that allows you to sit the scales BELOW the tray and supports the cup/s ABOVE the tray. But as it was more than a hundred dollars I thought I would see what I could do myself. Photos are of a prototype but if I am lazy it might last some time before I go for an improved Mk II.
    All works extremely well. Only change might be to make the cup platform a bit deeper as the cups only just reach the PF outlets. You also have to be sure nothing is fouling during a shot so as to not interfere with the measurement.
    Dimal, lemoo, matth3wh and 6 others like this.
    caffeinated lemoo's Avatar
    Oct 2011
    Perth, WA
    330
    that's actually quite brilliant
    I too have a giotto and a set of scales
    hmmmmmmmmmmmm
    Nov 2013
    1,502
    I'm assuming the thing you found is the ONA Stem?
    Member LauriG's Avatar
    May 2019
    Cairns, FNQ
    71
    Brilliant!! ONA obviously were real quick at copying your design. I like it.
    Junior member
    Dec 2010
    27
    Yep Ona Stand. Wasn't sure about listing product names.
    Senior Member matth3wh's Avatar
    Jul 2009
    Mid North Coast NSW
    980
    Thanks for the inspiration Meggs. I have the same Brewista scales and have been thinking of making something up for my Appia II machine.
    Nov 2017
    Maddington, Perth. Wa
    988
    A folded bit of stainless would be nice..
    Back to the laser cut guy!
    matth3wh likes this.
    Junior member
    Dec 2010
    27
    Brewista Scale stand Mk II
    Finally got around to making an improved stand for my Brewsita scales. Looks much better than previous prototype. Has even earnt me "brownie" points for improving the kitchen decor.
    NB If you make a stand spend a LOT of time getting suitable measurements. You need enough space to allow scale to react and stand needs to clear base of espresso machine and enough space to get cups under portafilter.
    Dimal, noonar, level3ninja and 2 others like this.
    16,881
    Nice job Meggs...
    Mar 2018
    11
    Nice idea! Something I might try with my 3D printer
Tags for this Thread
