Results 1 to 26 of 26
Like Tree20Likes
  • 1 Post By level3ninja
  • 4 Post By Lyrebird
  • 1 Post By roosterben
  • 1 Post By LeroyC
  • 3 Post By flashpixx
  • 1 Post By gunda
  • 1 Post By gunda
  • 3 Post By Meggs8
  • 1 Post By Dimal
  • 2 Post By robusto
  • 1 Post By flashpixx
Thread: Brewista Smart Scale II Issues
    Senior Member flashpixx's Avatar
    Dec 2013
    Perth Western Australia
    277
    The scale is starting to misbehave when on the drip tray weighing a shot.
    It turns itself off/on and shows weird weights. Works perfectly on the benchtop, and was working well on the drip tray.
    The scale remains dry, although the drip tray will have hot water in it so is exposed to steam/heat.
    The scale is fully charged.
    Has anyone come across this issue??
    On a side note I dont really like the smaller buttons on the Brewista, they are a but fiddly when sitting on the drip tray, sometimes I dont get the timer to work as I dont press it hard enough / straight down?? This is a personal thing as with age my dexterity isnt what it used to be
    Senior Member coffeechris's Avatar
    Jul 2011
    762
    Quote Originally Posted by flashpixx View Post
    I havent had the issues you have mentioned, but i will now keep a eye out in case it does happen.
    As for the buttons, i tend to agree, I sometimes think ive pressed the timer, only to look back and see i haven't.
    I must admit i find it hard to spend over $100 for a set of scales, hence why i bought these.
    Nov 2013
    1,664
    I would suggest it's steam/heat related. Try putting something thin and flat under the scale when it's on the drip tray and see if that helps. Either way it will spell an early demise for the scale if you keep exposing it to whatever is causing this.
    Dec 2013
    277
    Is the Acaia Lunar any more robust? It is advertised as a drip tray scale and timer
    Nov 2013
    1,664
    Mine hasn't missed a beat in 2 years, but I only use it on the drip tray when dialling in. They do apparently die after about a year in a cafe environment when recessed into the drip tray, but for home usage I can't see that happening. It's always a good idea to use the supplied rubber mat to keep the heat away that bit more. That all being said, they are ridiculously expensive for what they are, but nothing else seems to survive as well.
    flashpixx likes this.
    Oct 2015
    176
    I have a Felicita Arc which is the same hardware as Acai Lunar used it daily on drip tray for 6 months but only 10 coffees per week. Going strong and no issues so far.
    Dec 2013
    277
    Thanks. I’ve been meticulous with the Brewista but there is no way it can’t be exposed to heat and steam.
    My preferred workflow is to weigh the output so as exe as they are perhaps a Lunar, or a Felicita Arc as suggested by roosterben, might be the way to go.
    I had hoped the Brewista may have lasted a little longer. It’s only a month old!
    Dec 2013
    277
    Thanks Ben, I’ll look into one. Your usage is the same as mine
    Quote Originally Posted by roosterben View Post
    Jun 2018
    592
    I use a couple of the cheap Ebay* "coffee scales" in the winery for things that fall between the floor scales and the lab balances.
    They have so far survived everything thrown at them (sometimes literally) and frankly for about $20 a pop if they break I'll replace them. I generally decry our throw away society but sometimes the cheap Chinese crap actually works.
    * Java-"the price of liberty is eternal vigilance"-phile will delete any link I post, just enter "coffee scales" into the search box on EvilBay and they'll pop up.
    Dimal, robusto, flashpixx and 1 others like this.
    Oct 2015
    176
    I used the Brewista as well and found the buttons small and hard to press. My workflow is to tare grinds container then weigh the beans before single dosing. Then I tare with a cup and move the scales to the drip tray while grinding. Then when making a double shot I use the second mode which is manual timer and weight. I start the timer once pre-infusion finishes. On both scales I find all other absolutely useless. There would be some which would be good for pour over but they are much too slow and fiddly for espresso. They are crazily expensive but I manged to get a new set for $200 shipped of EvilBay, I think they are worth it. Another option could be the Hario scales, reviews aren't that great for espresso but I think they have timer and weight and big buttons.
    Oct 2015
    176
    Forgot to mention I would replace or get a refund on the Brewista as it claims to be water resistant and suitable for use on a drip tray. I would say you have a decent case for a warranty claim if you bought it new.
    Dec 2013
    277
    As you would expect, I used the scales on the drip tray today to make 4 espresso, no problem at all. I made sure the drip tray was empty and the machine expelled the water after the pull well away from the scales.
    As was mentioned earlier I’m concerned the scales are on their way out.
    I bought them from a site sponsor so yep thanks Ben, I’ve already been in touch with them.
    Dec 2013
    277
    It looks good Ben, about $30 less than a Lunar
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,299
    What are you doing that sees the scales exposed to steam?!!! No scales will handle steam as it will bypass even the best seal. I’d suggest maybe either an adjustment of workflow is required or a downgrade in scales. I’ve got a set of cheap, no name 0.1g scales that I bought online that I use on the drip tray. They’ve had water and coffee accidentally spilled on them but I never intentionally expose them to steam. They’ve lasted at least a couple of years. I check them for calibration occasionally and they’ve extremely accurate, even after I applied some grip tape to the pad to stop the cup sliding around.
    Dec 2013
    277
    What are you doing that sees the scales exposed to steam?!!!.
    Possibly sounds worse than it is, steam from hot water in the drip tray is what I was referring to
    Sep 2013
    2,299
    Ah ok, so you’re not aiming the steam wand at it like I was picturing then. That’s good. I had a laugh!
    A little bit of steam coming off some hot water in the drip tray could still be bad for a set of scales, but I wouldn’t have thought it would kill them too quickly. Maybe it has, but maybe you’ve got a dodgy set of scales too. If they’re not very old you could probably exchange them.
    Here’s the no frills set that I use. Hasn’t missed a beat:
    Dimal likes this.
    Dec 2013
    277
    Sent a message to the vendor, they’ve asked for a video of it playing up.... which it hasn’t done since haha...
    If I can Ill arrange an exchange
    Dimal, LeroyC and level3ninja like this.
    Dec 2013
    277
    Exchanged for the Lunar... ouch!!
    Jul 2014
    198
    One way to avoid any potential issues with a scale on the drip tray is to use an ONA Stem. Not cheap, but clever, well-made and works well. May not suit those small ebay scales such as the one pictured in post #16.
    17,122
    I imagine you could knock-up something very similar using a 3D printer...
    Jul 2014
    198
    If you've already got a 3D printer, yes. If you've got to pay someone to print, depends on the cost. And on the quality of the print you receive.
    As I mentioned in that recent Decent thread (not the long one), a number of people have designed a stand similar to this to work with the DE and the bluetooth Skale 2. I had such a stand printed for me. Wasn't overly cheap, and while it worked, it wasn't the greatest quality. I bought the ONA Stem. Sometimes it's just simpler and easier to pay for quality. If I had a 3D printer, or knew someone who did, I may have stuck with that approach, although it wouldn't have the adjustable height, which is a nice feature.
    Junior member
    Dec 2010
    Paynesville, East Gippsland
    48
    You could build something like this. My scales were getting wet ad messy and hard to fit under PF and didn't want to spend heaps on retail adaptor.
    Dimal, flashpixx and gunda like this.
  23. #23
    17,122
    Yes, your device came immediately to mind, very schmick indeed...
    Several CSers own 3D printers so I imagine it would be something that could be accomplished.
  24. #24
    Feb 2005
    2,918
    Or put the scale in a transparent lunch bag, ziplock bag or similar.
    Dimal and flashpixx like this.
  25. #25
    Oct 2019
    7
    Great scales but a little fiddly
    Hi Flashpixx - I'm generally happy with the Brewista, given the price point compared to the Acaia. My grinder has the Acaia built in so the grind is taken care of. I sit the Brewista forward of the group head discharge on my ECM Technika, so that a couple of CM hangs over the front edge. Don't have any problems. I use it to time the pre-infusion on Mode 5, then go on to run the espresso but use the PID on the ECM for timing. It all works well.
    Like you, though, I find the Mode & Power buttons the wrong way round. They are really small and require a good strong fingernail to activate. The power button is behind the mode button. The mode I use is 5 so don't need to change that, whereas I do need to turn the machine on and off regularly. It is illogical to have these two buttons this way round. On the right hand side the Tare button is at the front and the Timing button at the back. That seems ok but the button size, when fingers aren't as nimble as they used to be, could be a little bigger.
    As to reliability, they have been rock solid so far but that is only around 4 weeks. I'm sure I wouldn't be the only one here to be curious as to how you are finding the replacement scales ;-)
  26. #26
    Dec 2013
    277
    Thanks for that. I found it more and more unreliable however I think it got wet once too many times.
    I do miss the simplicity of the Brewista, the ability to auto-tare without having to auto start another function was very useful, say to auto-tare the bean container before grinding. I still sometimes forget, fortunately the a Tiamo ss cup weights 110.4g haha.
    Now I’m used to the Lunar it is quicker than the Brewista, and the buttons work without a second thought. However as I weigh the grind output then the extraction, I’m taring manually for each.
    quester likes this.
