Results 1 to 3 of 3
Thread: silvia steam tips
    Nov 2007
    4
    silvia steam tips
    Hi there all, does anyone know if its possible to get different tips for the silvia steam wands? If so, where from, im in NZ but dont mind ordering from oz. would a multi hole style tip give better results than the single hole on these? The commercial machine at work has 3 holes and creates awesome microfoam....but then again its commercial. Btw the steam arm is on my gaggia. (just putting it out there so people know i have the gaggia 100ml steaming power not the 300ml silvia power)
    Cheers guys :)
    3,498
    Re: silvia steam tips
    Hi love-lafare....
    I very much doubt the Silvia could provide enough steam for a 3 hole tip..... so very unlikely you would get much action from a 100ml boiler with a 3 hole tip!!!!
    There is quite a difference in the volume of steam a commercial can produce (mine has a 17L boiler)..... and even the 1.5L prosumers produce enough steam for a 3 hole..... but once you get below that.... the volume of steam just isnt there.... and without the volume the velocity of the steam drops.... and so does the texturing ability- plus you will empty the steam in no time flat!!!
    So stay with the single hole.... generally manufacturers know best ;)
    14,665
    Quote Originally Posted by love-lafare link=1194675726/0#0 date=1194675726
    Hi there all, does anyone know if its possible to get different tips for the silvia steam wands? If so, where from, im in NZ but dont mind ordering from oz. would a multi hole style tip give better results than the single hole on these? The commercial machine at work has 3 holes and creates awesome microfoam....but then again its commercial. *Btw the steam arm is on my gaggia. (just putting it out there so people know i have the gaggia 100ml steaming power not the 300ml silvia power)
    Cheers guys *:)
    Hi LL...
    Keep in mind also that you have a red hot element in a rapidly emptying boiler when you are texturing with a Silvia. Its not too hard to overcook the element and then if youre lucky, the over-temp cutout will protect you....If not, its most likely a new boiler and $$$ and :(. I recommend that you do not texture more than one 600ml jug of milk for 2 cups without priming the boiler. It saves trips to the service man with a dead machine ;)
  1. Silvia - Steam Tips
    By wattgn in forum Milk Froth and Bubbles
    Last Post: 7th January 2019, 02:39 PM
  2. GPP steam tips
    By WSullivan in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 10th December 2009, 10:44 PM
  3. Where to buy Silvia steam tips?
    By gregpullman in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 24th January 2008, 08:39 PM
  4. Steam tips for EM6910
    By thegoodies in forum Brewing Equipment (non-machine specific)
    Last Post: 16th December 2007, 04:22 PM
