Results 1 to 3 of 3
Thread: Thermosyphon restrictor valves
    Sep 2005
    499
    I know that Expobar and Vibiemme have a thermosyphon restrictor valve available as a spare part.
    The Expobar part looks like a lifesaver lolly and the VBM is a brass cylinder with a hole bored through. They both have the effect of reducing the opening in the grouphead supply pipe to less than or equal to 3.0mm. They reduce the thermosyphon action (and temperature) of water supplied to the grouphead. They are installed to reduce the length of cooling flushes.
    Has anyone had experience with the "before and after" performance of either add-on?
    Paolo.
    14,665
    Re: Thermosyphon restrictor valves
    Quote Originally Posted by Paolo link=1195420431/0#0 date=1195420431
    Paolo.
    Hi Paolo,
    Restrictors are installed standard in all Aust. VBM, ECM, Expobar and most other HX machines.
    They work ;)
    Aug 2004
    2,312
    Take care.
    there is nothing wrong with having to do cooling flushes, but it does mean a bit of water is wasted before you brew.
    If you modify a machine from the way it has been set up, this can have other effects...its the old "every action has a re action" thing.
    Fitting smaller than standard restrictor(s) will cool the group head & will indeed reduce the size of the cooling flush, but it can also result in your cooling the through put of brew water to less than optimal termperature for your coffee.
    So you can end up with something that doesnt require a cooling flush, but that may well produce under extracted, sour brew.
    Best left alone.
    If she aint broke, dont fix her!
    Regardz,
    FC.
  1. Thermosyphon restrictor sizes and actual location?
    By Apple in forum Brewing Equipment (non-machine specific)
    Last Post: 24th October 2016, 09:19 AM
  2. Hario flow restrictor
    By Jason2013Honey in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 9th April 2013, 06:21 PM
  3. Pre-infusion and flow-restrictor - on all e61 hx machines?
    By rival81 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 16th March 2010, 08:53 AM
