Results 1 to 3 of 3
Thread: Electric Jug PID for French Press, Presso etc.
    Apr 2007
    596
    This looks a pretty neat gizmo 8-) for $99.50 USD.
    I would post the link but the people selling it also sell PID Kits and I dont wish to run foul of site policy rules.
    This plug-and-play temperature controller can be used for controlling the temperature of electric kettle to one degree precision. To operate, plug the kettle to the socket of the controller on the back, drop the sensor into the pot from top and place the cover, turn on the power of controller and kettle, set the cooking temperature and timer. It will do the rest of job for you.
    The sensor used is specially designed for immersion in the water. The sensor cable uses multi-strand high strength alloy wire jacked with virgin flouropolymer that is safe for food processing and durable for high temperature. The sensor tip is sealed in stainless steel housing with proprietary medical grade sealant that is certified by USP class VI test.
    Instead of using thermocouple or RTD temperature sensor, this controller uses thermistor sensor that is that at least 10 to 100 times more sensitive. The result is a better precision control and stability. We believe this is the only plug-and play PID controller using thermistor sensor on the market that is under $1000.
    10,496
    Re: Electric Jug PID for French Press, Presso etc.
    Why not boil some water, wait for it to cool down a little (use a thermometer) and voila, water at the right temperature for well under $1000.
    Feb 2005
    2,804
    Ditto Thundergod.
    In any case, I doubt that the PID would achieve anything meaningful.
    For instance, while the setting is 196F, as the water is poured out into a cup or whatever, it is going to lose several degrees instantly.
  1. Rocky and French press
    By drovers-sunrise in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 6th April 2013, 09:09 AM
  2. Getting the most out of a plunger/French press
    By acoggins in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 7th March 2011, 11:11 AM
  3. French press
    By coastal_coffee in forum Brewing Equipment (non-machine specific)
    Last Post: 6th June 2007, 05:37 PM
