Results 1 to 6 of 6
Thread: water behaviour question
    Oct 2007
    792
    hi,
    after 2 strong lattes tonight it was time for a little clean up and then discovered that w/o the shower screen in place, the water exiting the middle hole of the group head comes out faster / harder and tends to flick about the place while the water from the four perimiter exit holes is calmer.
    hope the photo sort of helps in my description.
    im wondering if this is normal(ish) behaviour or is the pressure / temp too high?
    cheers
    aaron
    Oct 2007
    792
    Re: water behaviour question
    ahem...cough....(silence)....
    feeling a little silly...replaced the shower screen and realised (and why I ask did this not occur BEFORE posting) that the middle exit hole with the problematic water is kinda like plugged by the screw.... :-[
    BUT the water DOES NOT come out straight from the four remaining holes..should it?
    Jan 2007
    541
    It doesnt come out "symmetrically" on Silvia either, but its a moot point since its all going to hit a tightly packed puck jammed against the shower screen.
    Oct 2007
    792
    thanks reubster
    so i should worry less about assymetrical, messy water and worry more about interest rates? :-?
    Oct 2007
    38
    the shower screen is there as a diffuser, so worrying about interest rates is prob a better option :)
    Oct 2007
    792
    thanks people.
    time to refinance me thinks :-/
  1. Long Black hot water question
    By doubler_a in forum General Coffee Related...
    Last Post: 14th July 2011, 08:57 AM
  2. Rancillio Silvia question - hot water ?
    By beanie_kid in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 6th March 2011, 06:31 PM
  3. Question about drawing water now that I have replaced the in tank water softner
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th August 2009, 09:43 PM
  4. Water Question :S
    By Shimmy in forum General Coffee Related...
    Last Post: 11th January 2009, 04:39 AM
  5. [m]: Water Question :S
    By TC in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th January 2009, 09:49 AM
