Results 1 to 2 of 2
Thread: Replacing Group Seal
    Dec 2004
    117
    Hi there,
    Im sure we all have replaced a group seal before, but I was keen to know if anyone has a tip on how to get the old one out. The screw driver trick does the job eventually, but it takes a while and leave some scratches behind.
    Must be a better way. BTW I have a Silvia.
    franjae
    Dec 2004
    Earth!
    16,138
    Re: Replacing Group Seal
    I use a hard plastic spatula to work the gasket down far enough until I can get the blade of a 90 degree screwdriver on it to then pull it the rest of the way off. If its on too tight to simply pull off put a pliars on the other end of the 90 degree screwdriver and hit it with a suitably heavy tool. ;D
    Java "Gotta love a good tool" phile
  1. Breville Group head seal replacing.
    By jham66 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 25th October 2010, 10:23 PM
  2. Ikon - Replacing seal on milk steamer?
    By grolschie in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 12th January 2010, 05:46 AM
  3. Tips on replacing seal in EM6900? I must be missing something!
    By heretic in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th November 2009, 11:06 AM
  4. silvia still leaking after replacing gasket seal!
    By dweeby_espresso in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th June 2009, 04:59 PM
  5. Replacing Group Seal - Part 2 HELP!!!!!
    By franjae in forum Brewing Equipment (non-machine specific)
    Last Post: 2nd July 2005, 08:46 PM
