Results 1 to 5 of 5
Thread: Help to choose between
    Mar 2008
    7
    Hello guys.
    I have a little problem. I want to buy coffee machine but there arent very big range of choice in my city. So I stuck between these models:
    Breville BES200
    Saeco V.Veneto DLSil
    Saeco Gran Crema
    Saeco MagicEspresso
    Krups XP400030
    Which one do you think is better and why?
    Also, there are some more expensive models which probably are ok too. But than I want to know are they really better or not:
    Breville BES400
    Saeco M.Cappucino
    Breville 800ESXL
    Help me plz =)
    Nov 2006
    1,673
    Re: Help to choose between
    Firstly, What is your budget, and by that, I mean how much are you willing to spend?
    What city are you in?
    There are much better machines available than the above, it all depends on your budget.
    You also need to factor in a grinder too.
    Also, you can contact one of the site sponsors and have a chat with one of them.
    Mar 2008
    7
    I live in Russia and we havent all brands on our market.
    So looks like Im stuck just with models and brands above and need to choose between them. All them are within my budget as I wrote.
    What about grinder, Im going to buy Breviiles one. And there are too just saeco, breville and krups grinders on the maket.
    Mar 2006
    703
    Hi Spacer,
    I can not remember much about any of the machines you mention, but as a guide, I suggest avoid anything with thermoblock, look for something with a boiler. Aluminium boilers are common in the cheaper machines and require filtered water and regular descaling to get decent life out of them, but they are capable of making good coffee. (Small boilers will limit steaming capacity a bit). Also better if you can get a non pressurised PF with the machine, or you can modify some of the pressurised PFs....depends initially how fresh your coffee beans are.
    The machine will be limited by the quality of the grinder....is worth spending more on a grinder, even buying over the internet if possible to get a better one than those you mention, and maybe use a plunger till you can afford the machine.
    Regards
    Bullitt
    Sep 2007
    Northlandia
    1,363
    In Soviet Russia, espresso machine pours you!
    The Breville BES400 (Ikon) has a stainless steel boiler and a looks like good value for money at the bottom end of the scale - pretty sure theres at least one Coffee Snobs regular who uses this machine...
  1. Choose a $300 Grinder
    By glau in forum Grinders
    Last Post: 27th September 2009, 12:49 PM
  2. Help Please to Choose Machine
    By kazu in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 24th August 2009, 12:57 AM
  3. First machine - which out of four do i choose?
    By jonlongblack in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd September 2008, 09:59 AM
  4. Too many to choose from
    By JBetts in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 8th September 2008, 07:05 PM
