Results 1 to 3 of 3
Thread: Nova Espress - Moka Pot Made in Italy
    Jan 2007
    Perth, Western Australia, Australia
    791
    Ok guys and gals, *I went to the open air supermarket the other day. (The recycling centre at the local tip) *Open Air supermarket sounds better though. *I managed to pick up for 50c each, 2 x Pyrex plungers (one person size) and a Moka Pot. *What I would like to know is some details on the Moka Pot as I am an espresso machine user and first time stove top pot maker.
    I have attached a photo of the pot for you to check it out and give advice.
    1. Has anyone seen this brand and if so is it any good. *(Nova Espress- Brevettata Made in Italy)
    2. The top and bottom do not seperate and it is different from other moka pot setups so a little harder to clean - Best way to clean this?
    3. It is aluminium and I have heard that Aluminium leave nasty taste - is this try or can I get a decide cup out of this.
    4. Tips for brewing a good cup, *How much coffee to I put into the basket - Do I tamp and press lightly or not at all?
    Any other comments or suggestion are welcome. *Even if you so throw it in the bin as it is crap. *Still makes good coffee nostalgia for 50c.
    DONT USE
    Jan 2008
    432
    Re: Nova Espress - Moka Pot Made in Italy
    hi
    you use this the same as any other moka pot plenty of instructions on the web
    i have one the same
    but basically
    fill lower chamber with water, to the bottom of the safety valve
    fill coffee chamber with coffee, i overfill and wipe with crooked finger, this way the filter compacts the coffee properly.
    coffee ground approx drip filter or medium to fine.
    wipe gasket before putting together
    place on stove top abnd medium heat and let it heat and bubble up
    when the water boils in the lower chamber it uses the steam to force the water through the coffee
    as with a conventional coffee machine the grind and quantity in the basket is critical
    using the right blend/ roast produces a very nice coffee
    cleaning with litlle bit of citric acid or lemon juice this time only
    make a couple of cups to re oil surfaces and discard
    normally wash after use in hot water,
    graham
    Senior Member Dennis's Avatar
    Feb 2007
    4,512
    Hi Goodies
    I suggest you go beyond the basics and take a look at Robsters posts on how to use a moka - his results will make you drool.
    here http://coffeesnobs.com.au/YaBB.pl?num=1174971088/3#3
    and here http://coffeesnobs.com.au/YaBB.pl?num=1175047754/0#0
    As for cleaning it, personally, Id start with a scourer and detergent, and maybe live with/try the results before trying anything harsher.
  1. OLYMPIA ESPRESS
    By Excalibur in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 12th August 2014, 04:52 PM
  2. Help with old Nova Espress Stovetop
    By chipparoni in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 27th September 2008, 09:14 PM
  3. Where to get a new gasket for a Nova Espress Moka
    By aimeebailey in forum Brewing Equipment (non-machine specific)
    Last Post: 30th April 2008, 11:44 PM
  4. [m]: Where to get a new gasket for a Nova Espress Moka
    By Dimal in forum General Coffee Related...
