Results 1 to 4 of 4
Thread: NEED SOME HELP CLEANING A BOILER
    Jul 2007
    31
    Hello everyone.
    I was just wanting some advice from those who are in the know, of how to clean an already dismantled 300 ml boiler?
    What cleaning agents are safe to use and what to avoid?
    Also, what kind of silikon should I be using on the seals at the time of putting it back together?
    Thank you for your inputs.
    regards : Spressoman
    Mar 2005
    2,165
    Re: NEED SOME HELP CLEANING A BOILER
    SM,
    Depends whats in it but if its just scale then a citric acid solution would do the job. Dissolve some Citric Acid in hot water at a ratio of 1g to 100ml of final solution and add it to however much cold you need to make it up. E.g. to make 1L, dissolve 10ml in hot water and add it to ::) 990ml of cold water. Rubbery figures of course, something along those lines will do.
    I wouldnt use silicon for the seals; just get new ones is the best way if theyre available.
    Nov 2005
    333
    Hey spressoman,
    Did you manage to get a replacement tube thinggy for the inside of the boiler, or are you going to try making one yourself?
    I reckon Greg Pullman will be able to tell you anything you ever wanted to know about Quaha Junior II boiler repairs. He makes a damn fine tamper, too!
    Rob
    Jul 2007
    31
    Hi Rob.
    being patient --waiting for parts from Lygon imports--they meant to be in the mail.
    I survived 40 odd years without " the real stuff" so whats a couple of weeks.
    Fingers crossed no more "nescoffee " from next week.
  1. cleaning the Breville dual boiler
    By tonym1 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th January 2012, 11:18 PM
  2. Replies: 5
    Last Post: 28th June 2011, 06:40 PM
  3. Silvia Cleaning - Use vs Frequency of Cleaning?
    By Dalspec in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th September 2008, 12:44 AM
  4. Cleaning Silvias boiler.
    By JR in forum Brewing Equipment (non-machine specific)
    Last Post: 27th February 2005, 08:18 PM
