Results 1 to 4 of 4
Thread: Green stuff out of steam wand
    Jun 2006
    BRISBANE
    1,998
    Hi all - noticed that the FAEMA Dues 4 hole (which not does not get a lot of use given the 2 hole up the other end) has slight greening of the end (on closer inspection its a build up not wearing away of the chrome plating) and light green stuff on the top of the drip tray accumulating underneath where the outlet of the steam wand sits...any ideas?
    PS. Its been about 6 months since I pulled the bung and did the messy job of a full boiler flush. I usually just drain the boiler as per the book via the hot water tap which of course does not get rid of all of the water. I wonder if its the lack of use of the 4 hole tip because it does not happen in the 2 hole and the 4 hole has an occasional drip from it...so it may be that I need to give it a quick hit occasionally.
    DONT USE
    Jan 2008
    432
    Re: Green stuff out of steam wand
    put new seals in the steam valve and give boiler good flush
    no drip = no stains
    graham
    Jun 2006
    BRISBANE
    1,998
    Thanks Graham - I didnt think it was a big problem because water and brass can lead to green...
    Cheers matey
    Jul 2007
    2,288
    Sounds like its got a cold!
    A good flush with vitamin C should fix it.
  1. Silvia squeaky steam knob & leaking steam wand
    By Kasa in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th January 2009, 11:39 PM
  2. Changing Steam Wand Gaggia Classic to Silvia Wand
    By pricespringer in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd May 2008, 12:53 PM
  3. [m]: Changing Steam Wand Gaggia Classic to Silvia Wand
    By Dimal in forum Milk Froth and Bubbles
    Last Post: 23rd April 2008, 03:33 PM
