Results 1 to 3 of 3
Thread: Krups Krap
    Apr 2008
    7
    Krups Krap
    i am having troubles with my Krups machine pictured... it comes with a pod attachment but when i use a pod in it, it blows the seal out and sprays everywere. (the seal looks ok condition)
    Does anyone else have this problem?
    Also the "easy frother" attachment is as good as a straw. ATM i am just using it without it but am after a more perminant solution.
    cheers Azza
    Mar 2005
    2,165
    Re: Krups Krap
    Hi Azza,
    It sounds like somethings not right in your setup for sure, maybe the wrong attachment, wrong basket or the wrong type of pods; but I doubt youll get a lot of feedback on pod attachments because pods are basically an tidy, expensive way to get stale coffee. I wont go into all the problems with pods over freshly ground coffee as there are other threads which deal with that, but suffice to say if you ditch the pod attachment and get yourself a decent grinder instead youll get far better results than you are at the moment, yes even with a Krups.
    The tagline under your avatar reads Lifes to (sic) short to drink bad coffee - I agree; the above will be your second step away from bad coffee and into the realms of whats really achievable.
    Apr 2008
    7
    Re: Krups Krap
    thanks for the reply Greg, the pods were realy only an experiment to see if i could make coffee quite in the morning as to not wake people. experiment that went badly wrong. Also i will add that i got the pods for like 3 bucks on clearance from the supermarket so thought they were worth trying out the attachment for.
    i have a grinder and all kinds and blends of beans. although i am not into the home roasting yet i would like to soon as i have time and money for the set up!..
    cheers
  1. From Krups to...????
    By Boofy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd March 2009, 11:18 AM
  2. Krups Servicing or WANTED Broken Krups
    By peterg70 in forum Brewing Equipment (non-machine specific)
    Last Post: 30th January 2009, 06:35 PM
  3. [m by=735E5A565B370 destboard=Brew dest=1233124948]: Krups Servicing or WANTED Broken Krups
    By Dimal in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th January 2009, 07:27 PM
  4. Krups baskets for Breville 820:which Krups machin
    By wappinghigh in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 17th December 2008, 08:07 PM
