Results 1 to 2 of 2
Thread: temperatue surfing via steam switch
    Feb 2005
    3,073
    Has anyone tried to temperature surf using NOT the brew switch, but the STEAM switch?
    The idea, of course, is to time and switch off well before the steam thermostat cuts out, because by then the water would be too hot for coffee extraction.
    Why would you bother? Just in case the normal brew temperature is a little below desirable, which can be the case with many machines.
    Interesting thought which would require instruments and experimentation to find the ideal times.
    Dec 2004
    Earth!
    16,153
    Re: temperatue surfing via steam switch
    I actually did that with my Briel back in the day and found it helped prevent sour shots. I had to be careful though as if I left it on too long youd then have burnt tasting shots.
    Java "Fiddling with the new toy" phile
  1. EM6910 Steam switch broken?
    By prh in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th May 2011, 11:13 AM
  2. Temp surfing
    By tonym1 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd April 2011, 11:08 AM
  3. Rancilio Silvia - steam switch ON whilst brewing?
    By Toad in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th January 2011, 12:27 PM
  4. Temperature surfing.
    By Boris in forum Brewing Equipment (non-machine specific)
    Last Post: 10th January 2005, 11:48 AM
