Results 1 to 4 of 4
Thread: Acid for Scale Removal
    May 2005
    Perth
    1,333
    I thought Id start a new thread on this.
    As we speak, my Bezzera hx is soaking in a solution of sulphamic acid. I bought it from Bunnings. It is 41.2g/litre so in its present dilution it is quite dilute, probably about 10g/litre.
    I normally use citric and if this doesnt do the trick by tomorrow morning, I will use citric acid.
    If you have any stories, suggestions etc, please let me know.
    Grant
    17,466
    Re: Acid for Scale Removal
    Hi Grant,
    Maybe drop a PM to Javaphile or Mauricem who you have already been swapping ideas. I know Java has competed an extensive refit of his Cimbali Semi-Auto which involved the removal of significant scale build-up.
    The information exchange could then be redirected to the open forum for all to learn from :D
    Mar 2004
    Internet
    17,330
    I use "edible acid" by choice, a solution of Citric and Acetic.
    If that doesnt move it then CLR is great, but needs a lot of rincing to make sure you dont cup the nasties later.
    http://coffeesnobs.com.au/YaBB.pl?num=1108007340/11#11
    Dec 2004
    Earth!
    16,153
    I used Citric Acid in pretty strong concentrations and did several soaks on the heavily scaled parts with some physical abrassion used between soaks to help with the removal of thick areas of scale. It took awhile but eventually did the job. :)
    Java "Been there, done that, hope to never have to do it again!" phile
  1. Acid & Spice...What is the Difference?
    By Mariner in forum General Coffee Related...
    Last Post: 3rd April 2012, 10:58 PM
  2. Citric Acid Descaling
    By vicroamer in forum Brewing Equipment (non-machine specific)
    Last Post: 15th July 2010, 05:49 AM
  3. Concentrated Citric Acid Solution
    By Coffee_Kid in forum General Coffee Related...
    Last Post: 15th November 2009, 11:43 PM
  4. Citric Acid How to
    By clarexican in forum Brewing Equipment (non-machine specific)
    Last Post: 31st May 2005, 01:12 PM
