Results 1 to 3 of 3
Thread: help with my brasilia century cappuccino
    Apr 2008
    1
    Hi Everyone,
    I have just purchased,what i think to be a brasilia century,the machine is in good order,and everything seems to work as it should-good steam,plenty of hot water.One problem when i go to make an espresso i get a flat lifeless coffee,with no crema,and not particularly hot.I was running the machine from the tank,the previous owner said this could be my problem,i have now plumbed into the mains-no difference.
    * The boiler seems to fill as it should.and heat up well,running on just over 1.5 bar-but the standard of coffee is a mystery,i am using the correct grind etc.
    HELP PLEASE I AM AT A LOSS????????
    THANKS
    May 2008
    600
    Re: help with my brasilia century cappuccino
    hi. *It could be lots of things. *I had a quick look and gather it is a hx machine with vibe pump? *In that case, I would not have expected plumbing in to make any difference. *I dont think the coffee would be coming out cold. *Your boiler is well hot enough (1.5 bar), and the hx would heat it adequately. *If you run it without any coffee in the filter the water should come out pretty hot (too hot to touch). *You should be looking to grind to about 30ml in 25 secs (single shot). *Adjust your grind/tamp until you get that, and see if anything improves. *if you do this, and if your coffe is ok (not too old, not from safeways!) and you still have problems then maybe you have a pump problem, or are losing pressure somewhere.
    Damian.
    Apr 2007
    1,687
    Hi russnik,
    welcome to CS!
    Question; what type of coffee are you using? Where are you getting it from? What type of grinder have you got also?
    YeeZa
  1. Brasilia Century - thoughts
    By aer0 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 31st July 2012, 01:26 PM
  2. Brasilia cappuccino del machine big leaks from tap arm and ovp valve.
    By daycar in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th March 2011, 02:55 PM
  3. Brasilia Cappuccino - water flow too slow
    By VB in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 18th November 2009, 10:29 PM
  4. Replies: 0
    Last Post: 15th November 2009, 12:23 AM
  5. WBC Cappuccino
    By Intellidepth in forum Milk Froth and Bubbles
    Last Post: 11th August 2008, 09:39 PM
