Results 1 to 8 of 8
Thread: Aeropress Grinder setting
    Nov 2007
    131
    I use an aeropress at work - Generally i grind finer than espresso - I use my rocky one or two notches finer than i use with the double basket(LM). Am interested in the grind settings used by other members - especially those with a rocky relative to espresso settings
    16,613
    Re: Aeropress Grinder setting
    Gday argon,
    I just use the same setting as I would for espresso, mainly because I havent been able to taste any difference between this setting and the "Slightly finer than Filter" setting recommended in the AeroPress user brochure, so have left it there, Dont think I want to go any finer than this though as it would slow down the brew time too much Id reckon.....
    Feb 2007
    149
    Argon,
    Ditto with Mal. I seldom re-adjust my grinder settings for the AeroPress. Ideally you want it somewhere between (filter) coarse and closer to (espresso) fine but given Im able to produce a brew in ~20s with relative ease, Im not too fussed about changing my settings everytime I toggle between my Espresso machine and the AeroPress. Go any finer and youd probably have to pump a bit of muscle to push the (plunger) press down.
    Cheers, Andrew
    Feb 2008
    1,339
    Hi argon - the aeropress is designed for a coarser, not finer grind-size than espresso.
    Using the same setting as espresso will work, but affect the flavour...and youlll need much more effort. ;)
    Nov 2007
    131
    thanks everyone - next batch ill try a grinder setting 1 step coarser than espresso
    16,613
    Quote Originally Posted by cuppacoffee link=1213501180/0#3 date=1213525189
    Truth be known, Im just a lazy bugger Dennis ::) and I really cant detect any flavour difference..... Probably due to my palate, not the AeroPress... ;)
    Senior Member Dennis's Avatar
    Feb 2007
    4,512
    Quote Originally Posted by Mal link=1213501180/0#5 date=1213607704
    Mal, if you cant taste the difference, then I sincerely doubt anyone can! ;)
    16,613
    Quote Originally Posted by Dennis link=1213501180/0#6 date=1213614315
    Whoa! :o Thats a big call mate.... Dont think I could live up to that :-?,
  1. Using a spice grinder for aeropress?
    By Jonathon in forum Grinders
    Last Post: 5th April 2013, 11:01 PM
  2. Aeropress grind with Lux grinder?
    By drovers-sunrise in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 20th April 2011, 10:41 PM
  3. grinder setting
    By summercrema in forum Grinders
    Last Post: 9th November 2008, 10:17 PM
  4. Grinder for aeropress
    By argon in forum Grinders
    Last Post: 10th September 2008, 09:55 PM
