Results 1 to 17 of 17
Thread: Grindenstein mod
    Dec 2007
    22
    Grindenstein mod
    Howdy,
    I bought myself a grindenstein recently because my Sunbeam one was too big. Its neat but, like CoffeeGeek observed, surprisingly loud. I quickly concluded this was due to the bar material because Id noticed the Sunbeam, which is quieter, had a wooden bar where the Grindy had plastic (or so I thought). So I set out to replace it with a bit of wooden dowel.
    After a Herculean effort forcing out the bar, I discovered its actually solid steel with plastic caps on either end. Not surprising its loud! Retrospectively, it would have been a hell of lot easier to just pull one of the caps off and push the bar out than try and drive the cap through, but at that stage I thought it was just a plastic cylinder. Actually, the rubber tube has moulded ribs that enclose the bar and recesses at the end for the caps. Good construction.
    This also meant the dowel I had lovingly crafted based on the diameter of the caps wasnt going to fit. Luckily I had an unused cheap wooden spoon lying around whose handle happened to be just the right diameter so I stuffed that in, sawed it off and voila!, quiet(er) knockbox. I left the caps off in case I want to do it again but they could easily go back in for an invisible job.
    Obviously this mod isnt going to appeal to those who like to whale on the bar and/or make lots of noise but theres probably some other quiet-freaks out there. Heres a pic of the bar and the not-yet-sawn-off spoon.
    cheers,
    Liam
    Dec 2007
    22
    Re: Grindenstein mod
    The original bar.
    Apr 2008
    32
    No wonder mine feels so solid!
    Jul 2008
    63
    hmmm my Grindenstein had a plastic bar which broke 2 weeks after I bought it, due to the amount of thumping required to remove the soggy puck from the pressurised portafilter on the Breville 800es, so I fitted a length of 16mm dia aluminium tube, no problem with it since.
    with the new Domabars portafilter it only requires a gentle tap to remove the puck so the original plastic bar insert would still be ok.
    http://flickr.com/photos/54203117@N00/2711640613/
    sdg
    sdg is offline
    Mar 2008
    368
    Guys, I am totally mystified. Why wouldnt you start with a bit of plastic pipe if you wanted to build your own? :-?
    Senior Member Dennis's Avatar
    Feb 2007
    4,513
    Quote Originally Posted by simone link=1216206611/0#4 date=1217585900
    Its the male brain simone - no further explanation should be necessary. ;D
    sdg
    sdg is offline
    Mar 2008
    368
    I dunno -- when I 1st saw these things, I couldnt believe that they (Grindenstein in this case) could charge so much for an itty-bitty plastic bucket with a rod added. But to pay it, and then butcher the thing anyway -- wow :o
    Jul 2008
    63
    Quote Originally Posted by simone link=1216206611/0#6 date=1217588316
    I dunno -- when I 1st saw these things, I couldnt believe that they (Grindenstein in this case) could charge so much for an itty-bitty plastic bucket with a rod added. But to pay it, and then butcher the thing anyway -- wow *:o
    yes I agree the price is over the top for what you get, seeing them listed on ebay at $33 to $40 when for not that much more you can buy a metal Sunbeam box.
    I think I only paid $20 for mine a couple of years back, but it lasted 2 weeks before the plastic bar broke, yes it was plastic no metal insert like the new ones have, so I fitted an alloy tube to fix it, I could have used a dowel if I had one the right size.
    a cheap option would be to use a length of PVC pipe with a cap glued at one end and dowel with a silicon or rubber tube fitted into the top.
    Mar 2006
    703
    I have a cheap knockbox that was made for me using some 100mm dia poly pipe, and a plastic rod with screw on caps, and which has also been fitted with a lid (standard poly end cap) to keep the smell in.
    Works a treat, looks a bit ordinary, but my wife has not complained about the smell, and you can wash it if so desired.
    You can custom make the height to suit your requirements.
    So far has been robust and relatively quiet.
    Bullitt
    10,496
    Quote Originally Posted by Bullitt link=1216206611/0#8 date=1217978175
    with a lid to keep the smell in.
    Whats wrong with the smell of coffee?
    Jul 2007
    2,288
    Guys, I am totally mystified. Why wouldnt you start with a bit of plastic pipe if you wanted to build your own? *:-?
    OT
    I made mine with a 1 kg honey bucket, and a bamboo stick pushed through silicon rubber tubing. Disassembles easily, quiet, cheap.
    Mar 2006
    703
    Quote Originally Posted by Thundergod link=1216206611/0#9 date=1217978585
    Clarification...Nothing wrong with the smell of freshly made coffee...
    however those with sensitive noses might not appreciate the smell of coffee pucks, that could be a few days old, sitting in the knockbox.
    Im genuinely surprised that some commercially made units arent available with a lid.
    Bullitt
    Apr 2007
    1,687
    Yeah, I can imagine the lids getting pretty manky after a while, after the "outta site, outta mind" attitude wears off.... haha
    Senior Member E-Gene's Avatar
    Sep 2007
    Melbourne, Australia
    323
    I say if the smell gets to you then youre not really a coffee drinker...just kidding. I say just pop it into the bin.
    Jul 2008
    63
    the Grindenstein is only big enough to hold 6-7 double shot pucks, so I usually empty it every second day or so, they dont have a chance to go mouldy, anyway a lid would be nuisance.
    Apr 2007
    1,687
    I empty my G-stein every day.
    17,575
    Empty my Stein about three or four times a day 8-).... Oh, hang on; I was talking about my Beer Stein; sorry :-[
    Mal. ;)
  1. !!SOLD!!: Grindenstein Knock Box
    By chalermchait in forum SOLD
    Last Post: 29th July 2010, 03:16 PM
  2. Grindenstein: sticky knock ring
    By haiironezumi in forum Brewing Equipment (non-machine specific)
    Last Post: 7th January 2010, 11:56 AM
  3. Grindenstein Knock Box
    By coughienewbie in forum Brewing Equipment (non-machine specific)
    Last Post: 10th October 2009, 07:35 PM
  4. Grindenstein Knockbox AND Coffeelab Tamper
    By SlowRain in forum General Coffee Related...
    Last Post: 20th April 2009, 08:59 AM
