Results 1 to 6 of 6
Thread: Ceramic steam tap
    Apr 2008
    Brisbane
    5,113
    Ceramic steam tap
    Just thought I would enquire about better more precise steam control that also stops leaks and drips.
    Can one purchase as an original or aftermarket ceramic washer kit or whole On - Off tap to suit HX machines such as Bezzera, VBM ect
    Would the ceramic disc seal a pressure steam wand or is it only suitable for water
    I am hopeful that a sponsor or someone with steam experience can answer this query
    The thought came to me when I had the need to change tap washers in the in-laws home
    It was easier to fit a new flick mixer with ceramic disc as it gave one better control and most importantly no drips
    I have read on several posts in the past that machines left powered on all day had problems with leaking wands and ran dry, causing damage to the coffee machines
    So I think the ceramic disc washer would be a fantastic mod if it is suitable and if it can seal a steam wand
    Any thoughts??
    16,978
    Re: Ceramic steam tap
    Gday KK,
    Yes it has been done on at least one machine that I know of, not sure about any of the other makes though... :-?
    Apr 2008
    Brisbane
    5,113
    Thanks Mal
    I just had a look at the schematics on the Coffee Parts site of both the Brasilia and the Bezzera steam valve assembly and they are nothing alike
    If I got a complete Brasilia ceramic steam valve body (from the USA) I fear it will not be suitable for my Bezzera
    Still it gives me hope that it may be possible?
    May 2007
    100
    Kosmo,
    Do you know that your machine has a safety water level cutoff in the boiler as well as the water reservoir so apart from making a bit of a mess a leaking tap should not damage your machine.
    Apr 2008
    Brisbane
    5,113
    Yes
    I do know that my Galatea has a cut off switch
    My steam wand knob is also a soft touch so I donít need to turn it too tight to seal, and that sometimes is not tight enough
    That in turn causes drips on occasions
    I just like the idea of no drips
    But a ceramic disc valve body could benefit machine owners without the low water cut off switch
    Aug 2008
    14
    Hi mate
    JR Lenards in Sydney are the importers of Brazilla.
    There are 2 type of cermaic valves 1 is 1/4 turn and the other 2 full turns, I perfer the 1/4 turn.
    They are very dependable type of valves I work on this type of machine daily and find very few that leak.
    It should fit straight on to the pipe, not sure about length.
  1. Ceramic Cup with Lid
    By lilmeh in forum General Coffee Related...
    Last Post: 13th September 2012, 10:10 PM
  2. Why S/S jug instead of ceramic creamer?
    By NewToEspresso in forum Milk Froth and Bubbles
    Last Post: 20th July 2007, 09:39 PM
  3. anyone have ceramic insulation
    By telemaster in forum SOLD
    Last Post: 8th August 2006, 06:00 PM
  4. Ceramic Cups
    By JR in forum General Coffee Related...
    Last Post: 14th June 2006, 02:13 PM
