Results 1 to 6 of 6
Thread: group handle with guage
    Aug 2007
    34
    I have a spare rancilio group hand and a 10bar 40mm pressure guage. Im keen to attatch the guage to the handle to make a usefull tool. Any tips on where to tap the hole to monitor the pressure within the pour?
    Jul 2008
    Port Fairy
    2,993
    Re: group handle with guage
    Hi Ralph
    you also really need to put a valve on the output to choke the portafilter flow as you are trying to test pressure at say 60ml/25 seconds.
    You really need to make the volume the same as with a tamped puck from what I have seen of the Scace devices (think this might apply more to the temp version). This doesnt apply if you just want to pop a measuring glass under the flow and keep the pump running while you time at a certain pressure.
    May 2008
    600
    Hi Ralph, As you have your machine apart, I would just temporarily mount the gauge after your pump. It will give you a true reading of pretssure when pumping with coffee in the filter. If you ahve the fittings and a length of copper it would take about 5 mins to put in, and about the same to take it out when you are done.
    Damian.
    Feb 2008
    44
    Hey Ralph,
    Iv been thinking of doing something similar with one of my protafilters, Im just missing a connection that fits between the gauge and the main brass coupler. Its not finished yet but this is whats been done so far, maybe I can attach some sort of thermometer in there as well, somehow? maybe thats going a bit too far....
    10,496
    I just bought mine from Coffee Parts.
    Feb 2008
    44
    I was going to do that but thought I might try and make one myself, with this setup Im hoping that I will be able to adjust the poor rate with the end tap. and for around $30, why not try!
    just found my camera so here what iv done so far.
  1. Group Handle at 5pm
    By gbatterley in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 15th April 2012, 07:30 AM
  2. Where to buy the group handle for EM6910
    By colinwen in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 31st March 2010, 09:03 PM
  3. How to change Handle of Group handle
    By JustinD in forum Brewing Equipment (non-machine specific)
    Last Post: 7th October 2009, 08:57 PM
