Results 1 to 2 of 2
Thread: adding a vacuum breaker?
    Mar 2008
    194
    Well, having had to open up the Oscar the other day has reminded me that I was thinking of trying to add a vacuum breaker to it sometime.
    Whilst the putting one in seems to be fairly straight forward, I do not know exactly what sort of vacuum breaker i would need to put in, are they calibrated for different levels of pressure? Will any vacuum breaker from another machine work?
    I am a bit hesitant to do this to fix what is seemingly a minor issue on the Oscar (being the omission of a vacuum breaker leading it to require the steam valve opened as part of its warming process) but its all a learning experience.
    tips, warnings, etc all appreciated.
    17,120
    Re: adding a vacuum breaker?
    Quote Originally Posted by raphec link=1224626659/0#0 date=1224626659
    Even if you fit a Vacuum Break Valve to your Oscars Boiler "raphec", it is still good practice to follow the procedure above (as well as blowing off the steam after switch-off and leaving the Steam Valve Open as the machine cools down) as VBVs tend to be unreliable by the very nature of their design and will often stick closed.
    Given that, it might be simpler to just leave your Oscar the way he is and continue with your normal routine.... :-?
    Cheers, :)
  1. Via Venezia tripping breaker
    By noidle22 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 17th April 2013, 10:12 PM
  2. LM GS/3 Vacuum Breaker Modification
    By simonwar in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 22nd March 2013, 09:13 PM
  3. Recently bought BZ40, Vacuum breaker not working
    By pup26 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 14th January 2011, 05:24 PM
  4. What is the function of a vacuum breaker?
    By NewToEspresso in forum Brewing Equipment (non-machine specific)
    Last Post: 10th October 2008, 11:03 AM
