Results 1 to 3 of 3
Thread: seized pump
    Jul 2005
    131
    seized pump
    Hi,
    Has anyone had a similar problem or some advice for me? * We had a weekend away and I thought that rather than settle for “instant” I would take my old Krups Nova (circa ’98) with me. * Yes, I know, but if you’ve practiced it will produce a reasonable shot. *[smiley=thumbsup.gif] *Anyway, it was working when put away after upgrading to the Silvia. * Long story short, the pump (ULKA) appears to have seized up. * I thought that I would soak it in some citric acid or CLR and see what happened! * What do you think? * Will this stuff it completely?
    Bruce
    Aug 2004
    2,312
    Re: seized pump
    Billy,
    this is very simple if the pump feed is by a simple silicon hose in the top of the water tank.
    Get yourself a veterinary syringe with end large enough to fit neatly into the feed hose. Fill the syringe with water, start the machine pumping and plunge the syringe into the line.
    CAREFUL not to plunge the syringe too forcefully or you can blow the other end of the feed line off the pump...then you have to pull the body to get to the pump to push the feedline back on.
    The above should "unseize" the thing and it should pump through. Stop the pump, put all back together and.....whalla.
    This is not uncommonm and is very easily remedied in most cases as above.
    If on the other hand the water feed is through a valve in the bottom of the tank you may well have to pull the body so you can get to the feedline to the pump, and the rest is still as above.
    Regardz,
    FC.
    Jul 2005
    131
    Re: seized pump
    Thanks FC,
    Will give it a go and let you know how I get on.
    Billi
  1. EM6910 no main pump, low hot water and steam pump. Had red light. now just not worki
    By bocos in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th February 2013, 08:25 AM
  2. Should a vibration pump pressure be set higher than a rotary pump?
    By NakiChap in forum General Coffee Related...
    Last Post: 25th June 2012, 04:11 PM
  3. procon pump - metal filter in pump housing
    By rider in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 13th November 2009, 12:17 AM
  4. £34,000 of fake coffee seized in UK
    By Koffee_Kosmo in forum General Coffee Related...
    Last Post: 8th November 2008, 06:40 PM
