Results 1 to 12 of 12
Thread: Giotto Premium - Uneven pour
    Sep 2008
    63
    When using the double porta filler, my Giotto Premium seems to fill the right hand side with more espresso than the left. Usually the left has 30ml by the time the right only has about 20-25ml. I have checked my bench with the spirit measure and that seems straight on. I have also given the porta filler a good soak and clean but that seemed to make little difference.
    Any ideas?
    Aug 2004
    306
    Re: Giotto Premium - Uneven pour
    Uneven tamping may be the cause. Make sure the cofee is level in the basket and your tamp is even.
    16,869
    Gday "cm"... :)
    Most likely culprits are.... Your Giotto isnt sitting level on the bench and/or there is a bit of flashing in the PF spout that was missed after casting and needs to be gently filed off with a small round file.
    Cheers mate,
    Sep 2008
    63
    Has anyone experienced that their group head spout (the double) does not line up straight (or perpendicular) to the machine? Mine is about 20-30 degrees around. Trying to align the spout straight involves unscrewing the spout from the group head, enough to leave it a little too loose.
    Any suggestions?
    Jan 2008
    1,756
    are you saying the whole group handle is 20-30 degrees around? or just the spouts......if its the wholegroup handle.....group seal buggared?, if its just the spouts, use some plumbers tape to wrap around the thread on the handle till it tightens at the correct point......
    cheers
    warren
    Sep 2008
    63
    Quote Originally Posted by 1713352C2C2936212E400 link=1228021806/4#4 date=1263504618
    Just the spouts. Group handle itself is fine.
    May 2008
    4,096
    Quote Originally Posted by 7061767E72707B7A7D76130 link=1228021806/5#5 date=1263504816
    Just the spouts.Group handle itself is fine.
    No - the spouts on my GPP are perpendicular to the handle.
    You dont want the spouts loose. Try the plumber tape mod as Warren suggests but, as its a new machine and you are also getting an uneven pour, Id take it up with your machine supplier as a potential warranty issue.
    Sep 2008
    63
    Quote Originally Posted by 777D687F7F706462110 link=1228021806/6#6 date=1263506002
    I think I may have caused a little confusion here actually. *I HAD a Giotto Premium that had an uneven pour. *I have since upgrade to the Giotto Premium Plus, which has the off-centre spout. *I was looking through my old threads remembering I had some sort of similar issue on the Premium and came across this one! My GPP does NOT have an even pour.
    Sorry for the confusion - will try the tape and let you know.
    May 2008
    4,096
    Quote Originally Posted by 7766717975777C7D7A71140 link=1228021806/7#7 date=1263506287
    My confusion - I didnt check the date of the OP in this thread.
    Id still check with the supplier first as I wouldnt be modding a machine under warranty without their knowledge/go-ahead
    Sep 2008
    63
    Just checked with the supplier and - guess what - the suggestion was to use some plumbers tape wrapped around the thread. Funnily enough, they said that it was actually a good think to do anyway as it stops small amounts of coffee getting caught up in the thread.
    So I did that - wrapped some plumbers tape around the thread about half a dozen times and it now seems I have a perpendicular spout again!
    Jan 2008
    1,756
    No worries ;D
    Jul 2007
    2,286
    Quote Originally Posted by 4C5D4A424E4C4746414A2F0 link=1228021806/9#9 date=1263512326
    Just checked with the supplier and - guess what - the suggestion was to use some plumbers tape wrapped around the thread. *Funnily enough, they said that it was actually a good think to do anyway as it stops small amounts of coffee getting caught up in the thread.
    Nice work!
    Im glad you were able to remove the spouts easily. When I tried that on my previous VBM I had to put the spouts in a padded vice, and the pressure needed to move the spout had me very worried for the integrity of the handle. It flexed alarmingly and I was certain it was going to break before the spout turned!! Fortunately that didnt happen. :)
  1. Silvia uneven pour
    By philipmach in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th June 2011, 08:56 PM
  2. Warped/uneven panel on Giotto Premium Plus group head
    By drcoffee in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 12th August 2009, 09:34 PM
  3. Uneven Pour
    By its_an_epic in forum General Coffee Related...
    Last Post: 27th October 2008, 10:34 PM
