Results 1 to 4 of 4
Thread: Faema E98 Compact pouring double shots instead of single - Help
    Jun 2009
    1
    Hi
    Has anyone a user manual for a Faema E98 Compact? Have been using it, but cant find manual. Pressing single shot, it pours out about 60 mls instead of the required 30 mls. This is not to do with the consistency of the coffee and is due to how much water is dispensed.
    can anyone help with instructions or more perfrectly, a manual
    cheers
    Andrew
    Nov 2006
    224
    Re: Faema E98 Compact pouring double shots instead of single - Help
    60mls of coffee or water?
    Try holding down some of the buttons and see if it enters a mode where you can set the flow.
    May 2008
    600
    if you dont have coffee in, and push the button more water will come out than when you have coffee in there.
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    848
    Gday Andrew,
    I believe that Faema and La Cimbali are the same company now (or one owns the other) and that the E98 is similar, if not identical to a La Cimbali Jnr. If that is the case, check this link out for some programming instructions.
    http://www.home-barista.com/junior-b...g-started.html
  1. Faema, E98 compact
    By Aaron in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 16th September 2011, 08:49 PM
  2. Faema E98 Compact S1
    By stevedvsinc in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 24th March 2011, 08:18 PM
  3. Stupid question....double shots.
    By sambo200 in forum General Coffee Related...
    Last Post: 26th November 2009, 06:45 AM
  4. Should I buy a Faema e98 compact
    By konrad78 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 31st December 2007, 05:41 PM
