Results 1 to 12 of 12
Thread: Help: How to replace shower screen, gasket etc on Giotto Premium?
    Oct 2007
    95
    Can anybody point me to a thread that tells you how to replace a Giotto (Premium preferably) shower/group/gasket etc? Gumby-level step by step instructions / photos preferred ;D
    I know I have seen this somewhere but just cannot find it.
    Also would appreciate needed part numbers and such too if possible.
    Background: Machine is probably 2-3 yo as far as I know this has not ever been done.
    I am not having any troubles with mine, but from what I have read, I should do this anyway?
    Cheers!
    14,665
    Re: Help: How to replace shower screen, gasket etc on Giotto Premium?
    Quote Originally Posted by 272C3B2C2F22344D0 link=1244501410/0#0 date=1244501410
    Can anybody point me to a thread that tells you how to replace a Giotto (Premium preferably) shower/group/gasket etc? Gumby-level step by step instructions / photos preferred *;D
    Cheers!
    Easy Javaboy...
    1. Take stubby flat blade screwdriver
    2. Use edge of group as pivot point and screwdriver against edge of the shower screen
    3. Lever the whole lot down...
    Good luck!
    2mcm
    Oct 2007
    95
    Thanks... I thought it maybe as easy as that, but remember seeing lots of bits and bobs that came down with it (in a photo here: http://espressoparts2.zoovy.com/cate...upmaintenance/ (which was not specific to the GP, however)
    I didnt want to commit to the job and then not know how to put it all back together! :)
    Apr 2008
    Brisbane
    5,116
    I use a spoon handle to pry it off
    the Shower screen collar has the tiniest of rims
    you can use the spoon handle if not to thick to lever it off
    Using a chopstick also works well. It comes out rubber seal and all
    Putting it back - rub a tiny bit of food grade lubricant on the seal place it square on the PF and lock twist the PF to push it home
    Also another tip
    The seal will have 1 sharp edge and 1 rounded edge
    The rounded edge goes up ^
    Oct 2007
    95
    Hmmm.... Ive hit a snag. Got everything off but when I put it all back together and put the PF handle in, it goes past center when tightened and not stop at 90 degrees. *
    So took all the bits (new screen and group gasket) out and compared sizes. The old gasket appears to be about 1 mm taller (deep/thick). Whats going on there?
    The part number on the receipt says I was given:
    C449900229 8mm (ECM) gasket.
    The part number appears to be correct for an ECM Giotto Premium, which is what I have.
    Both (old and new) gaskets have a number 9 and the letters ECM on the other and no other writing.
    Any ideas?
    May 2008
    4,219
    Youll need to buy a spacer (a paper gasket). Give Cosmorex a call. They are likely to have some on hand otherwise you can order online from a sponsor. *Di Bartoli and Coffeeparts have them listed. Heres a pic:
    http://www.unpaid.com.au/product_details.asp?pid=197
    Its also shown (as a paper shim) on the site you posted in one of your earlier replies.
    Feb 2008
    1,339
    Quote Originally Posted by 53584F585B5640390 link=1244501410/4#4 date=1244628857
    They also come in a 9mm. ;)
    Oct 2007
    95
    Ok thanks fellas, how annoying.
    I will try to track down a 9mm one (thats what I thought the number 9 written on the gasket might have meant, obviously not?)
    Plan b is to find a paper shim/gasket.
    10,496
    You may need two paper shims.
    When I was accidentally given an 8mm instead of an 8.5 for my Expobar, Renzo came to my rescue with one paper shim.
    Apr 2008
    Brisbane
    5,116
    If desperate you can make a paper shim/gasket out of a cereal box or similar cardboard
    lightly grease to waterproof and its done
    Easy
    Oct 2007
    95
    Thanks all. The job was quite easy in the end.
    ...and boy was there a lot of filth in behind the shower screen!
    I went back to the store where the machine was bought (as well as the gasket) and they gave me a couple of thin rubber gaskets for free this morning. They did not have any other sized gaskets in stock.
    I will go home and give them a go tonight - dont envisage any problems. Next time I know that I either need an 8.5 or 9mm gasket.
    Apr 2007
    414
    you can order the shims from here next time if needed
    http://www.coffeeparts.com/machines/ecm.html
    i;m sure any other sponsor on here that carries the giotto will also have them in stock
  1. Giotto Premium Shower Plate falls off
    By pbags in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th July 2012, 07:54 AM
  2. shower screen removal
    By kooky in forum General Coffee Related...
    Last Post: 6th December 2009, 09:04 AM
  3. Giotto Premium group gasket installation
    By mj in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 22nd November 2008, 09:08 PM
