Results 1 to 10 of 10
Thread: Which machine to best suite me?
    Jun 2009
    1
    Hello everyone,
    I am new to this site, which I have been reading for an hour and still havent come across the answer to my burning question which is...
    Which machine is best suited to my needs, which are listed below.
    * Great dense froth, so will need to have a great frother which is quick and easy to use for a novice.
    * Grinder and machine all in one
    * Only required to do 2-8 cups per day
    * Budget is no more than $3000
    * Main use will be for cappuccino/hot chocolates
    This is all I can think of at the moment, but these are the main things that I would love to have in my new coffee machine.
    Can anyone please help???
    Jun 2009
    70
    Re: Which machine to best suite me?
    There are some really good machines in your price range but you must have a good grinder about $475 for a Rancilio Rocky is a great start.
    Apart from that a La Scala Butterfly, Expobar Minore III or Diadema Regal are all nice machines.
    You should have change from $3000
    If you want to go a tad over you can get a Rocket Giotto and Rocky. I have the Giotto its *awesome :)
    If you are getting gear at this end of the market then also invest in a Barista course @ William Anglis or something like that, Do this and you will get the very best out of you gear.
    Oh and Welcome to CS.
    Apr 2008
    Brisbane
    5,116
    Hi and welcome
    You need a HX (heat exchanger) machine
    Bezzera
    VBM
    Giotto
    Diadema
    Are some espresso machines to short list
    Good grinder is also essential
    Mazzer
    Compak
    Macap
    You need to road test the obove machines and pick the one that you like best
    Where do you live as a sponsor may be able to help with special CS pricing
    Caffeine Junky
    May 2009
    1,103
    Do you want a machine with a built-in grinder? This will certainly limit your choice and Im not aware of any such machines at that end of the price range.
    Nov 2006
    1,077
    Coffeelover101 your original request was for advice on a machine with a built in grinder.
    Now i am no expert here but from my reading of these forums over the last 1 - 2 years is that you are better off with a separate grinder purely for the quality of the grind. Starting with an appropriate grinder is a must and the suggestions so far are all good. I have a Giotto, not a new one but from all accounts the newer ones are even better than what i have and i have no complaints about mine.
    I would use the LHS "email all site sponsors" function and you will get some very honest no pressure advice back.
    Mal
    Feb 2009
    59
    Quote Originally Posted by 7C5851515252687C58445A58370 link=1245932728/2#2 date=1245933615
    HX or dual boiler (Expobar Minore III) ? Or is there a specific reason why HX is better?
    Dec 2007
    921
    HX is more in your price range dual boilers are "better" but more expensive, for around 2200 you can pick up a really good HX and $800 for the grinder means you should never need to upgrade (the grinder). Well thats just my opinion anyway.
    17,475
    Quote Originally Posted by 515F525D4A5C5D330 link=1245932728/6#6 date=1246060703
    That is arguable mate and probably better stated that it is an alternative to a HX rather than better than a HX machine. Best discussed in its own thread though.... ;)
    Not necessarily more expensive either ::)
    Dec 2007
    921
    Quote Originally Posted by 7A57535F523E0 link=1245932728/7#7 date=1246067295
    Hence the quotation marks ;D, alternative is a more accurate description. No argument here. ::)
    Site Sponsor
    May 2008
    Frenchs Forest NSW
    788
    Quote Originally Posted by 6468616162626B68716275363736070 link=1245932728/0#0 date=1245932728
    Hey coffeelover101,
    do you mean a super auto? That is, press a button and coffee comes out of the spout? All of the machines mentioned so far are semi autos, that is, you grind the coffee on your grinder, then lock in your handle and press a button or lift a lever. These make better coffee but require a "little"* more involvement. (* substitute "lot" for most on this forum ;)
    charlie
