Results 1 to 4 of 4
Thread: New Giotto Premium Plus - Creaking Noise. Normal??
    Oct 2007
    95
    HI all
    I have a new GPP (less than 1 month old) which makes a creaking noise for about a 1 second just before pouring starts. Is that normal?
    I also have the older Giotto Premium which never does this.
    Basically, after I lift the lever to kick off the brew process, the noise comes from inside the machine (pump?) after about 2 sec, just before the pour starts and last for 1 sec or so. It is fairly loud.
    Just thought I would check before bugging the supplier.
    Cheers.
    Apr 2008
    Brisbane
    5,115
    Re: New Giotto Premium Plus - Creaking Noise. Normal??
    Grease the cam
    That will fix it
    This will happen often after a chemical back-flush
    14,666
    Quote Originally Posted by 4A415641424F59200 link=1249168391/0#0 date=1249168391
    HI all
    Cheers.
    Hi Java,
    This is the "9 bar woofle" and very common. Its a good thing and on many machines is an indication of a correctly adjusted OPV. My old e-61 and my Giotto Pro both do it...
    Worry not...
    2mcm
    Oct 2007
    95
    OK thanks guys.
  1. ECM Giotto - Hissinh from the top , on and off hissing noise
    By acdc in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 22nd September 2012, 06:11 AM
  2. question - Giotto PP or giotto premium?
    By cafe_lover in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 30th January 2010, 12:16 PM
  3. Differnce between Giotto Premium and Premium plus
    By patto21 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st February 2009, 07:59 PM
  4. noise when pumping without coffee. normal?
    By damian1 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 12th May 2008, 04:52 PM
  5. ECM Giotto Premium
    By Dr_Kaldi in forum Brewing Equipment (non-machine specific)
    Last Post: 6th September 2005, 09:00 PM
