Results 1 to 6 of 6
Thread: Parts for Boema
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Parts for Boema
    This is for sale locally here in NZ, are the parts easy to get in Aussie?
    Only looking at it if I can get it for a few hundred to have a bit of a play with. Working condition.
    Also will this run on single phase?
    Jun 2008
    1,520
    Re: Parts for Boema
    loooks good for a few hundred :) has it got an internal pump?
    nice and shiny I had a laugh
    parts should be get-able direct from Boema as they are made (put together?) here.
    many parts might be the same as other machines? the group heads i have looked at on boemas look a lot like san marino ones, but i cannot confirm that the are
    Oct 2007
    New Zealand
    1,162
    Re: Parts for Boema
    Well it could well go for a bit more but I thought worth asking the Aussies about their very own brand :)
    pip
    pip is offline
    May 2007
    37
    Re: Parts for Boema
    Hi Chris,
    * * * * * * Ive got the non volumetric version sitting in my lounge room (aka storeroom for coffee paraphernalia) and its quite a nice bit of engineering. Inbuilt rotary pump, RL40 level controller, nickel plated boiler of around 6 litres and a steel chassis, and stainless steel clothes ! The element *is a standard screw in unit , so you can substitute a 2400 watt one and run it on a 10 amp supply - mine had a 2400 Watt element fitted from new , although others may have been 3600 Watt.The groups are similar to Bezzeras , with a big round o-ring group seal - and Boema in Sydney will happily sell spares for them.The only problem with them is fracturing silver soldered and brazed fittings ( its all copper and brass plumbing) ,and it does have to be plumbed in.But if youve got the room , theyll make lots of good coffee all day - and keep your kitchen warm too !!
    pip.
    Oct 2009
    5
    Re: Parts for Boema
    Hot news is parts are cheap too! 2400W 10A element is AUD$49, seals and gaskets come in generally under AUD$5 each. I am doing a rebuild on the same machine right now.
    Do it!
    Feb 2011
    11
    Re: Parts for Boema
    If you ph 0449 206 335, they are having a clearout of coffe spare parts, many brands, but Boema electrical, mechanical spares and groups seals, protafilters etc. CHEAP.
  1. So I was going to ask about Boema...
    By dsgfh in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 5th April 2007, 05:44 PM
  2. Boema?
    By gregpullman in forum Brewing Equipment (non-machine specific)
    Last Post: 11th January 2007, 11:27 AM
  3. Boema?,
    Last Post: 4th January 2007, 09:35 PM
  4. Boema
    By Lovey in forum Brewing Equipment (non-machine specific)
    Last Post: 21st November 2005, 01:48 PM
  5. Boema
    By franjae in forum Brewing Equipment (non-machine specific)
    Last Post: 12th September 2005, 04:46 PM
