Results 1 to 8 of 8
Thread: VBM Domobar - busted light
    Feb 2006
    459
    I was descaling today, and the right hand light (which I think is supposed to be green, but has not worked for ages) cracked the front off the lens and now doesnt mount properly.
    Where can I get a new one? Cant see it on coffeeparts.
    Also, how many flushes does the boiler need after a descale? Ive put at least 5 full tanks through it and it still tastes nasty...
    Also on that subject, Im not sure I didnt stuff the pressure gauge by overpressurising the boiler (forgot to open the steam valve when turning the pump on with the level sensor disconnected...)
    Jul 2007
    87
    Re: VBM Domobar - busted light
    Hi Matt,
    Re the light, give the guys at ECA a call. They should be able to help you
    http://www.espressocompany.com.au/spare-parts/DOMOBAR-SUPER-CATALOGUE-13.03.09.pdf
    If its the green, check page 7, part #11
    Re the other questions, Ill let someone with more knowledge answer on those.
    Caff
    Feb 2006
    459
    Thans Caff. I think its actually part 13 on that page ("Transparent gem"), but the images are so blocky as to be impossible to tell...
    as you can see, the face of the lens (sitting on top of the machine) has snapped off the barrel of it.
    Aug 2007
    569
    Hi Matt
    I had the same problem. Got one from Talk Coffee for about $3.50
    Any service agent for VBM should be able to get one in.
    Rgds
    Ben
    Feb 2006
    459
    Thanks to ECA, got sorted - new gem, new light (globe was blown also) and two new tap gaskets for steam and water. Very impressed with the low price of parts for a machine like this.
    Aug 2007
    569
    Quote Originally Posted by 05293C3C170321262F480 link=1256981214/4#4 date=1258194761
    Thanks to ECA, got sorted - new gem, new light (globe was blown also) and two new tap gaskets for steam and water. *Very impressed with the low price of parts for a machine like this.
    Good news, I actually ended up with a new bulb and had to glue my jewel. It all works, but good to hear ECA has stock
    Aug 2008
    12
    Ancient thread I know, but how do you actually install the replacement light? The clear end looks like it should unscrew but doesn’t appear to. What’s the trick?
    Aug 2008
    12
    And never mind, pulling straight out worked!
  1. VBM Domobar Super Power light
    By cksyd in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st February 2011, 06:08 PM
  2. I have seen the light
    By Bruce in forum Roasters
    Last Post: 8th June 2007, 09:42 PM
  3. Busted Silvia... little help?
    By adrian_lovell in forum Brewing Equipment (non-machine specific)
    Last Post: 19th May 2006, 11:00 PM
